Activity › Forums › Apple Final Cut Pro Legacy › External Program Monitor FCPX
  • External Program Monitor FCPX
    Posted by Patrick Morrow on January 7, 2014 at 4:50 am
    Hello,
    Can someone tell me what Black Magic product at the cheapest price, that can provide me with a feed from a laptop to an external monitor. I am looking for full program out.
    Thanks!!!
    Patrick Morrow
    Colin Mcquillan replied 12 years, 8 months ago 3 Members · 6 Replies
  • Shane Ross
    January 7, 2014 at 5:05 am
    Decklink Ultrastudio Mini Monitor. $140.
    https://www.blackmagicdesign.com/products/ultrastudiothunderbolt
    Requires Thunderbolt
    Shane
    Little Frog Post
  • Patrick Morrow
    January 7, 2014 at 6:02 pm
    Will that work with a Mac Book Pro? Can I install it myself?
    Patrick
  • Shane Ross
    January 7, 2014 at 7:22 pm
    If your laptop has THUNDERBOLT, then you simply connect a Thunderbolt cable to that box, and then the box to your HDTV. You will need to install the drivers for it. Those are found on the decklink.com site.
    Shane
    Little Frog Post
  • Patrick Morrow
    January 8, 2014 at 2:28 pm
    Hi Shane,
    You describe it as a box and it looks like a plug in board. Is this something that is external or internal?
    Thanks so much!
  • Shane Ross
    January 8, 2014 at 4:06 pm
    Click on the link again. Nothing on that link is a board…they are all external boxes. The one I mention, the cheapest…Mini Monitor…is a small box. Size of a deck of cards.
    Shane
    Little Frog Post
  • Colin Mcquillan
    January 10, 2014 at 5:48 am
    The Mini Monitor Shane suggests is a great affordable output device for monitoring. I do a lot of cutting while on the road and use one to tap into hotel TV sets or my SmallHD monitor that I travel with.
    One thing to keep in mind when using one of these output devices with FCPX is to set your viewer to “Better Quality” instead of “Better Performance” as you will not be able to see any fields/interlacing issues and such even on the external monitor. (When set to better performance FCPX only outputs at a lower resolution, even to the external display which can mask issues.)
    Colin McQuillan
    Vancouver, B.C.
