Activity Forums Audio external power for SD 552
  • external power for SD 552
    Posted by Rob Dunford on March 28, 2014 at 7:38 pm
    I want to find a cost effective way of powering my 552, without going down the NP1 route…..it seems for a simple set up of two batts, cup, plus charger I need several hundred $$.
    Looking around there are radio control batteries (NiMh) that come in various voltages, like 7.2, 9.6, 12v. Not expensive, and I am very competent with making up electrical stuff. For similar volts/capacity, I can be all set up for around $100.
    Has anyone been down this route and can share their experiences?
    Ty Ford replied 12 years, 5 months ago 3 Members · 6 Replies
  • Brian Reynolds
    March 28, 2014 at 10:30 pm
    I use small SLA batteries on my SD442 mixer it gives me abou 1/2 day (change at lunch break). [Battery 12v 1.3AH]
    https://www.jaycar.com.au/productView.asp?ID=SB2480
    Very cheap, works well and enough power to run the mixer, radio mics or recorder, 12v charger for phones and a strip of LEDs for night shoots.
    I have made a master switch with 2x DC inputs, the batteries can be ‘HOT’ swapped even during a ‘take’.
  • Rob Dunford
    March 28, 2014 at 10:35 pm
    I need it to fit the Petrol bag and not be too heavy…although this…https://www.componentshop.co.uk/12v-3700mah-sc-nimh-battery-pack.html is no lightweight, it would fit the bag.
    I like NiMh because of the high capacity.
    Did you fit an inline fuse to protect your gear?
  • Brian Reynolds
    March 28, 2014 at 10:41 pm
    No didnt worry about a fuse, I don’t often do over the shoulder shoots, most of my shoots are TV commercials where you can put the mixer kit on a chair or table so weight isn’t a primary consideration.
    I have also made an adaptor to go to a 4 pin XLR…. Got more than a few camera ops out of the poo either to run their camera or video monitor.
  • Ty Ford
    March 29, 2014 at 2:17 pm
    Hello Rob and welcome to the Cow Audio Forum.
    I use a rechargeable pack from BatteryGeeks and had the power lead terminated so it works with my 442 or 664. They were very helpful on the phone.
    https://www.thebatterygeeks.com/
    Regards,
    Ty Ford
    Cow Audio Forum leader.
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford’s Blog
  • Rob Dunford
    March 29, 2014 at 2:18 pm
    Did BG do the termination? or someone else?
  • Ty Ford
    March 29, 2014 at 2:29 pm
    I sent it to Eric Toline down in Florida.
    Hiroses make me nervous.
    audioetc@bellsouth.net
    Regards,
    Ty
