Activity Forums Apple Final Cut Pro External Playback monitor while keeping both viewers on main monitor
  • External Playback monitor while keeping both viewers on main monitor
    Posted by Steve Horswill-johnston on June 11, 2017 at 9:47 pm
    Hello all,
    I’d like to have an external playback monitor but keep both viewers on my main monitor. Possible? If it requires a Matrox box (or similar) what is the hardware I need? I know I can place viewers on the external monitor, but it removes it from the main monitor. I want to keep them in both locations.
    Thanks in advance!
    Steve
    Final Cut 10.3.4
    iMac (Late 2013, latest OS)
    Jeff Kirkland replied 9 years, 3 months ago 2 Members · 3 Replies
  • Jeff Kirkland
    June 11, 2017 at 11:53 pm
    setting AV Out to on in the menu should tell FCPX to use your external monitor as a broadcast display.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Steve Horswill-johnston
    June 11, 2017 at 11:59 pm
    Thanks. For some reason, I’m not able to make any change to that setting. You’re talking about in preferences/playback, correct?
  • Jeff Kirkland
    June 12, 2017 at 6:48 am
    You’re in the right spot. How is your monitor connected to the Mac? From memory it has to be connected via HDMI to show up.
