Activity Forums Apple Final Cut Pro Legacy External Output Issue
  • External Output Issue
    Posted by Mark Fanjoy on March 31, 2009 at 9:03 pm
    Okay, I’m stuck. I just hooked up my external TV monitor to view my FC project. I see picture when timeline is stopped, but video will not play to monitor, it goes black. When I stop the timeline, the still image pops up and snaps to the current image. Does this on any project and everything is rendered, even the green line stuff.
    Any ideas to determine if this is a FC issue or a hardware connection issue?
    Mark Fanjoy
    Wherever I am…I’m lost!
    Mark Fanjoy replied 17 years, 5 months ago 2 Members · 2 Replies
  • Shane Ross
    March 31, 2009 at 9:06 pm
    Is this DV? HDV? DVCPRO HD? What?
    Shane’s Stock Answer #8: External Monitor Viewing
    If you are working with DV, this is simple. First connect your computer to a camera or deck via firewire, Then connect the camera/deck to your TV/Monitor via RCA or S-Video.
    Then start up your camera and tv, then open fcp.
    Go to the View Menu, choose > External video > all frames
    VIEW>Video playback should be Apple firewire NTSC (If you are using an NTSC set)
    VIEW>Audio playback should be Audio follows Video
    Techinially, this should send synched video to your TV
    If for some reason you can’t view your timeline on your external monitor, there are a few things to try:
    1) Make sure that the camera/deck is connected and powered on BEFORE you open FCP.
    2) In the Final Cut Pro menu select AUDIO/VIDEO Preferences and make sure your signal is being sent out thru Firewire DV.
    3) Go to the menu and select VIEW>EXTERNAL>ALL FRAMES.
    4) Click in the % box above the image and select FIT TO WINDOW.
    5) Go to VIEW->refresh A/V devices
    6) Make sure the Log & Capture window is closed
    If you want it to play in both the canvas and the external monitor you need to go to the FINAL CUT PRO menu and select AUDIO/VIDIO settings and make sure MIRROR ON DESKTOP is selected under the PLAYBACK OUTPUT section.
    If you are working with HDV footage, FCP 6 allows you to view this via firewire, but ONLY as downconverted DV. It won’t look the best, but you can see it. To do this,
    If you need to view any format other than DV at full resolution, then you need to look into capture cards. Several standard definition and high definition models are available from https://www.aja.com and https://www.decklink.com. With these options you’ll need a proper monitor to view full broadcast colors, but all models allow for realtime standard definition downconvert, allowing you to view HD on an SD monitor.
    The Matrox MXO is another option that is output only, but allows you to view your footage on an Apple Cinema Display at full broadcast quality.
    Shane
  • Mark Fanjoy
    March 31, 2009 at 9:18 pm
    Thank you Shane for pointing me in the right direction. Problem solved, sort of! You clued me in on DV vs HD. This is my first HD project and that’s the problem. Pulled up an old DV home video, and it outputs real time just fine.
    I have a Blackmagic capture card for my Betacam SP deck. Thought it was only for digitizing. I’ll look and see if it also handles receiving and managing video for output.
    Thank you for pointing me in the right direction.
    You guys are too cool!!
