Activity › Forums › VEGAS Pro › External monitor via firewire
  • External monitor via firewire
    Posted by David Shirey on February 26, 2008 at 4:02 pm
    I’ve always used this Canopus ADVC-100 to preview Vegas on a CRT monitor, and lately its bothering me that there’s a slight video lag. Feels like maybe half a second, but when you run into a project that involved syncing audio cues its less than ideal. I’ve just always assumed that its normal for the firewire to lag a little since it has to pass through the converter box, but I’m wondering if between everyone else’s experience there might be a better solution?
    Do you all use faster devices that can pass a signal with no delay, or is everyone in the same boat as me and just not bothered by it? At home I can use my hdtv’s dvi input to have vegas just preview on a second monitor, but the office I work at is a little behind the times when it comes to hdtv.
    Joe Ruelle replied 17 years, 1 month ago 6 Members · 8 Replies
  • 8 Replies
  • Mike Kujbida
    February 26, 2008 at 4:52 pm
    Did you recently update to a newer version of Vegas?
    The reason I’m asking is that, after upgrading to Vegas 7, I noticed a susbstantial video lag on my external monitor.
    I don’t use a Canopus box like you do.
    My computer is hooked up to a JVC dual miniDV/SVHS deck.
    The analog out of this machine feeds my 15″ JVC monitor.
    My solution was to adjust the sync offset.
    Go “Option – Prefs – Preview Device” and adjust the “Sync Offset (frames)” slider.
    On Vegas 6 on my machine, it was set to 4 frames.
    With Vegas 7, I had to set it to 12 frames (the max) to get things back to normal.
    See if this solution works for you.
  • David Shirey
    February 26, 2008 at 5:22 pm
    I don’t know why it never occurred to me that could be fixed in software. The sweet spot for me seems to be 8 frames. Thanks for the help!
  • Mike Kujbida
    February 26, 2008 at 6:45 pm
    Glad to hear that it worked for you!!
    I got used to watching it on the Preview monitor until I stumbled across mention of this method on a Vegas forum somewhere. Sure glad I did 🙂
  • Charles Avanti
    February 27, 2008 at 12:54 am
    Hi Mike. I am using the same JVC set up as you. Computer–>firewire–>JVC deck–>S-video–>HDTV monitor.
    I have not edited any HD only SD. Does this setup output HD?
    Do I need something else for HD preview?
    Charlie
  • Mike Kujbida
    February 27, 2008 at 4:15 am
    Charlie, like you, I have yet to do any HD.
    Our current setup (yours & mine) isn’t capable of displaying HD because most of the components are only SD-capable.
    As I recall (and someone please correct me if I’m wrong), the way most folks are getting an HD signal to a monitor is by using the “Windows Secondary Display” feature that’s a part of Vegas.
    You’ll need a graphics card capable of handling the necessary resolution.
  • Bhavin Jivraj
    July 21, 2009 at 2:08 pm
    hi,
    I have just installed Geforce 6 6200 pci graphics card to my dell dimension 2400. I have both monitors working but cannot preview on external monitor in sony vegas even though I have played around with the ‘preview device preferences’
    Any suggestions?
    Kind Regards
  • Theo Van laar
    July 21, 2009 at 3:02 pm
    And you pressed the “television icon” on top of the preview window?
    Theo
  • Joe Ruelle
    August 30, 2009 at 12:22 am
    Had the exact same problem with the 6200 card and vegas 8. Installed vegas 9 and voila, problem solved. Seems the update solves some glitches with secondary display previewing and certain cards
