Activity Forums Apple Final Cut Pro Legacy external monitor setup
  • external monitor setup
    Posted by Maurik De ridder on July 7, 2008 at 10:23 am
    Hello…
    My work mainly consists of editing tv commercials/short movies/ commercial internet videos/
    I’m trying to set up a professional monitoring setup
    Just received the Blackmagic Multibridge Pro…
    Now it’s time to buy a decent external monitor…
    My eye caught the detail that the Multibridge has a HDMI output for HD monitoring,
    and the monitor of JVC (the DT-V24L1U) is HDMI compatible
    The DT-V24L1U is the little brother of the JVC DT-V24L1D except doesn’t have HDSDI support…
    (and therefore alot cheaper)
    Would this be a good setup for monitoring HD as well as SD
    Or do you need monitoring through HDSDI instead of HDMI
    Maybe someone can give me some feedback on this
    greetings Maurik
    Editor at Media Republic
    Amsterdam the Netherlands
    Editor@ Media Republic
    Mac OSX 10.4.11, FCP 6.0.2, Compressor 3.0.2, Color 1.0.2, Soundtrack Pro 2.0.2, DVD Studio Pro 4.2.1, Quicktime Pro 7.3, Flip4Mac HD Studio Pro
    MacPro Dual-Core Intel Xeon, 3 GHz, 3 GB RAM, 2x 23″ Cinema Displays, Decklink HD Extreme, JVC TM H150C
    Jerry Hofmann replied 18 years, 1 month ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 7, 2008 at 1:50 pm
    It’s a decent monitor, however it falls off radically if you’re not looking straight at it… If that’s not a problem, it should work fine. Not seen SD on one, but figure it’s OK, or you could keep the SD monitor you’ve been working with.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
