Activity Forums Blackmagic Design external monitor setup
  • external monitor setup
    Posted by Bobulous on September 16, 2005 at 1:54 pm
    hello forumness
    just got a decklink exteme (sweet!)slipped it into my g5
    trying to setup my component monitor with some bars
    now i did some surfing and came upon a little os9 app called test pattern maker by synthetic apperture
    now they have a good pdf on the set up but i dont know what bars to output out the app and put in my fcp timeline to setmeup
    i guess smpte bars ar good
    rec.601 for pal? (pal for sure as im uk)
    now here is the bit i need help with
    what is the coding for the decklink extreme?
    rgb (0-255) no setup
    rgb (0-255) w/ setup
    rec. 601 (16-235) no setup
    rec. 601 (16-235) w/ setup
    thanks dudes
    bob
    and hello lexerton!
    Lexerton replied 20 years, 12 months ago 2 Members · 3 Replies
  • Lexerton
    September 19, 2005 at 10:10 am
    ha ha
    just load up the bars from the viewer in FCP.
    bars should always be generated by the source. I see no reason not use the FCP bars.
    Hubba Hubba
    Lexerton
  • Bobulous
    September 19, 2005 at 12:33 pm
    stop yer laffin lex
    im only little
    see thing is
    everytime i generate a bar in final cut
    yon pluge bars are 2 of the same black then one grey
    if i take the frame into plotyslop then pippete it then i get zeros ont rgb on the 2 black then 1 on the grey
    can you generate one and email me with it
    nice one
    bobs
  • Lexerton
    September 19, 2005 at 12:51 pm
    Ho Hum
    Have you done tried looking at it in the viewer and tooling with the brightness / contrast just so you know it’s there?
    I suspect that the noted gamma wibbliness in and out of FCP might be smudging the issue with Plotyslop.
    Also it is always, rpt, always the video monitor that should be the reference, not the computer monitor.
    The colour meter app on my system registers 0,0,0 RGB for all three pluge bars on the comp monitor but on my video monitor they are there.
    Try shutting your curtains, that may help, just remember to open them again.
    Shabba Do
    Lex
