external monitor preview problem
Hello, I have a problem to solve for you professionals out there ☺
I recently bought an Intensity pro 4k to use with my HP Dreamcolor monitor and i have a weird issue that i can’t find a solution for.
When i start premiere pro cc 2015 some of my sequences work fine and i have picture thru the intensity card and on others (most of them) sadly i get a green pixely screen during playback and scrub but not when i am paused, weird.
I have tried different sequence settings and all kinds of footage with no luck and if i start a new project and import footage from the sequences that work the new sequence and project docent work ..
I am on a mac running OS X el captain and the latest adobe versions.
It works fine in after effects and resolve but not in premiere. mmmUpptill now i have been using a matrox card with no problems at all. I hope its something that is easily fixed because i do a lot of work in premiere.
Thanks for all of your ideas
/Christofer
