Activity › Forums › Apple Final Cut Pro Legacy › External monitor looks in-sync but not FCP
Posted by Kevin Allar on October 20, 2009 at 8:00 pmI’m shooting at 24 fps, P2 / 720p, and the footage looks out of sync on my timeline but OK on my exterior monitor. What gives?
Kevin Allar
Walter Biscardi replied 16 years, 10 months ago 4 Members · 3 Replies -
Kevin Monahan
October 20, 2009 at 8:09 pmSystem Settings > Playback Control. Adjust your playback offset. Try an offset of Zero.
Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro -
Chris Carroll
November 4, 2009 at 8:28 pmAre you monitoring sound coming from a deck or straight from your computer?
There will be a very slight (but noticable) delay from sound that comes from an external source (like a DV deck connected via firewire)
or similar setup.Just an idea…
Export to quicktime and double check the sync…its probably okay if this is your issue…
Walter Biscardi
November 4, 2009 at 10:06 pmWhat Kevin says. Your Playback offset is not set up correctly. Default is 4, but for any system with a capture card it should probably be set to 0.
Walter Biscardi, Jr.
Editor, Colorist, Director, Writer, Consultant, Author.
HD Post and Production
Biscardi Creative Media“Foul Water, Fiery Serpent” now in Post.
Creative Cow Forum Host:
Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
