Activity Forums AJA Video Systems External monitor DELAY
  • External monitor DELAY
    Posted by Tmjoey on June 15, 2007 at 8:05 pm
    Hi all,
    This is driving me nuts. Off and on (mostly off) my external monitor is lagging behind by about 4 frames. Working with FCP 6, regular old SD uncompressed 10 bit. It could be a simple setting, but I’m not sure because it is not consistent.
    Any ideas??
    Joey
    Tmjoey replied 19 years, 2 months ago 2 Members · 2 Replies
  • Szumlins
    June 15, 2007 at 9:26 pm
    Have you gone into System Settings -> Playback Control and set the offset to zero?
    Default is 4. It should be 0 while using AJA hardware.
    -Mike
  • Tmjoey
    June 15, 2007 at 11:11 pm
    Yep, but I have more info now and have somewhat isolated the problem, but now I’m not sure if it’s FCP or AJA related.
    If I click anywhere in my timeline and play forward, good to go. If I then pause and jog backwards, it’s off (sometimes). If I then go forward without clicking in the timeline (l), it’s off (usually), BUT I can always click the the timeline and play forward and it’s fine.
    Weird.
    I can work around by clicking and clicking, but not productive.
    Joey
