Activity › Forums › Event Videographers › External Microphone
  • External Microphone
    Posted by Richard Fender on May 13, 2005 at 6:16 pm
    Anyone with experience using external microphone? I occasionally am in a situation where I can not move around or there is no amphlified sound system in the facility.It would seem like an exterior microphone (directional) would improve the audio pick up already built in the camcorder (Canon). The microphone would have to have a standard 1/8″ plug, be self powered and have a rating of 600 Ohms. Any help or reccomendations would be greatly appreciated. TIA
    Chris Dolan replied 21 years, 4 months ago 3 Members · 4 Replies
  • Doug Graham
    May 14, 2005 at 2:08 am
    You have lots of audio choices, and almost all of them are better than the camcorder’s built in mic.
    If you just need an interview mic for a stationary subject a few feet from the camera, you can use a lavalier on the lapel, a handheld, or a shotgun mic on a boom pole manipulated by an assistant. For longer distances, use a balanced audio cable and get an XLR adapter box to interface the three pin XLR connection to the camcorder.
    If you do event video, or just need fast setup/teardown, and/or camera or subject mobility, you need a wireless solution. There are many good wireless mic systems, starting at around $400 or so. Or, get a minidisc recorder or an iRiver solid state MP3 recorder, and a lavalier mic to go with them. You can sync up the audio from these devices with your video footage in post.
    In almost every case, the key to getting good audio is to get the mic element up close to the sound source. The camcorder is almost always too far away for best results. Whether you accomplish this with a hardwired mic, a wireless system, or a separate digital recorder is up to you.
    Regards,
    Doug Graham
  • Richard Fender
    May 15, 2005 at 10:09 pm
    Thanks for the info. I primarily need help with the audio when I am in situation in the rear of a room/hall and the existing sound system is not sufficient. I get some improvement with Premere 6.5 audio edit T/L but quality leaves a lot to be desired. I am going to experiment with the suggestions you made. I am a relative newbe in this game which is becomming a hobby only. RF
  • Chris Dolan
    May 16, 2005 at 5:22 pm
    Doug,
    If you don’t mind, I’d appreciate comments on my post, down the page a bit, regarding wireless mics for a bride. Here is the url if you can’t find it: https://www.creativecow.net/forum/read_post.php?postid=111590189950550&forumid=11
    I ask because you mentioned the iRiver products and I wonder if you have any experience with them. I purchased the iRiver iFP 895 and am not very satisfied with the recorded sound.
    Chris
  • Chris Dolan
    May 16, 2005 at 10:37 pm
    Correction to my last post: The Thread is actually about mini disc recorders, but the link to the thread was correct.
    Anyone have thoughts on the issue of sound quality from the iRiver units?
    Oh, btw- sorry Richard for hijacking your original thread…just wanted to shed some light on the iRiver subject, since it was mentioned.
    -Chris
