Activity Forums Adobe After Effects External HD’s
  • External HD’s
    Posted by Phil Johnston on June 16, 2006 at 1:17 pm
    (Didn’t see a forum for this so just posted it here)
    Does anyone have an opinion on the best external harddrives to buy?
    I understand Lacie makes some good ones, but don’t know much about other brands.
    I’m on a mac but I’d like it to be compatible with PC’s as well.
    Which gives you the best bang for your buck?
    Phil Johnston
    Digital Animator
    _________________
    https://www.pwandj.com
    Michael Duff replied 20 years, 3 months ago 5 Members · 5 Replies
  • Ebarfield
    June 16, 2006 at 1:25 pm
    It may be just me, and they seem to have a good reputation, but I’ve had two Lacie drives go bad just out of warranty in the past 3 years, so I’m done with Lacie…I purchased a 1 Terrabyte Maxtor drive (USB) about a year ago, and it has worked nicely (so far).
    egb
    “deja vu all over again” — Yogi Berra
  • Mylenium
    June 16, 2006 at 3:37 pm
    We just got this week one of those Maxtor OneTouch III 1 TB external drives (RAID 0 SATA, connected via Firewire 800). Works pretty nicely, but of course those drives are not really meant for permanent use under maximum duress, so I expect it to break down once its time comes (presumably in 2 years).
    Mylenium
    [Pour Myl
  • Ebarfield
    June 16, 2006 at 10:29 pm
    That would be longer than my lacie…{;>}
  • Vince Becquiot
    June 18, 2006 at 12:38 am
    I have gone through about 30 hard drives through my computer life so far.
    And the winner is ? Seagate. All others have crashed on me within 4 years of continuous use.
    Not to go against any particular brand name here, and that may simply be luck, but expecially for external drives, this is the only name I now trust.
    They have, from what I have seen, the best cooling system around, and for an external hard drive that’s a very important factor.
    Vince
  • Michael Duff
    June 19, 2006 at 3:37 am
    I too have been running an external Seagate HD through a really cheap case I got from ebay. No cooling on the case and I leave it on for days straight, often with music streaming off it if I forget to close iTunes. Can’t be good for the drive, but it is nearly three years old and has never had a problem.
