Activity Forums Adobe Premiere Pro External Hard Drive set up for Pro
  • External Hard Drive set up for Pro
    Posted by Steve Mac kenzie on May 16, 2006 at 1:52 pm
    My current set up has a 250 Gig external hard drive for the raw footage and I use the internal drive for project and render files. For the sake of portability I was thinking of picking up a second external HD or condolidating everything onto the 250 gig. Non editors have been all over the place with their recommendations and what not so I need to hear from you about what will give the best performance.
    Thank You for your input!
    Steve Mac kenzie replied 20 years, 3 months ago 3 Members · 4 Replies
  • Harm Millaard
    May 16, 2006 at 3:13 pm
    Use eSATA Carbus adapter such as from Lindy and connect 2 eSATA portable disks. If you are going for HDV it will not be enough, but for SD that is sufficient.
    Harm Millaard
  • Harm Millaard
    May 16, 2006 at 3:18 pm
    There is even a 4 eSATA PCI-X card with Raid possibility for HDV.
    https://www.lindy.com/uk/catalog/01/00s/index.php
    Harm Millaard
  • Lloyd Coleman
    May 16, 2006 at 3:46 pm
    I know that what I am doing is not recommended, however, it has been working just fine for me. I have about 30 concurent projects that are spread over 11 external USB hard drives. It was a nighmare to try and track where all the files were, so I just put everything from one project on one drive (project files, raw footage, rendered files, etc). I am editing standard DV, not High Def. I have been doing this for over a year and have not had one problem with throughput, dropped frames, etc. I am not doing heavy compositing, but do sometimes have effects that take up 5-10 tracks at the same time. It sure has simplified my file tracking (although I still have a worksheet so I can find the project that I am looking for). I try and only keep 2-3 drives plugged in at one time because every time you plug a device into the USB hub it allocates space for that device and reduces the overall bandwidth for each one. In addition to the drives, I have a printer, mouse, scanner, graphics tablet and Ipod plugged into the USB. I am amazed at the flexability that USB provides. I am using standard internal 7200rpm drives that I put into external enclosures. Depending on what you are doing, you might find that this works for you also. Try a project on the drive you have now and see if it works.
  • Steve Mac kenzie
    May 17, 2006 at 3:31 pm
    Thanks for your input, your insight has helped me immensely.
    Steve
