Activity Forums Storage & Archiving External hard drive “refusing” to copy a file from hard drive
  • External hard drive “refusing” to copy a file from hard drive
    Posted by Mercedes Gonzalez on December 1, 2014 at 5:37 pm
    Hello everybody,
    something just happened to me that never happened before, I was going to storage a mov file in my external hard drive and I get this message: “The item “time coded sequence.mov” can´t be copied because it is too large for the volume´s format”. As you can imagine is plenty of room for the file in the drive, and even I tested copying larger folders and other mov files and no problem at all. Any suggestion what is going on? What does “volume´s format” exactly mean?
    Thanks a lot for your help,
    Mercedes
    In the battle with reality, no matter what, reality always wins
    Doug Metz replied 11 years, 9 months ago 3 Members · 3 Replies
  • Martin Greenwood
    December 1, 2014 at 6:27 pm
    Mercedes,
    The external hard drive may be formatted as FAT16, FAT32 or HFS.
    These older filesystems have a maximum file size of 2GB.
    How large is the movie file?
    If you reformat the external drive as HFS+ on a Mac or NTFS on Windows then you will be able to use larger file sizes.
    Martin
    CTO
    YoYotta.com
  • Mercedes Gonzalez
    December 2, 2014 at 6:57 pm
    Hi Martin,
    Thanks a lot for your response. The movie file is 7Gb and the drive have 508.81Gb available… As I mentioned before I tried to copy larger files than that: folders and mov files and no problem, it´s just with this particular mov file I get that window, and nothing is different from this mov files than anothers as far as I know. I just exported it from FCP with the the Time Code fx, that´s the only difference compared to other mov files.
    Any additional thoughts?
    thanks a lot,
    saludos,
    Mercedes
  • Doug Metz
    December 2, 2014 at 7:42 pm
    Hi Mercedes,
    The first step is to discover the actual format of the external drive. To do this, select it in the Finder and then from the File menu, choose ‘Get Info’ :
    Doug Metz
    Anode
