Activity Forums AJA Video Systems external hard drive Rec
  • external hard drive Rec
    Posted by Rashin Fahandej on December 29, 2007 at 1:31 am
    I am in desperate need of a good and fast external hard drive, that I can work off of.
    I use Final Cut Pro for my video editing. I only have one
    external hard with the USB connection with all my file in there, which I feel it would die on me any minute.
    I have been looking at Lacie 500G, Iomega 500GB UltraMax Desktop Hard Drive and LaCie 320GB mini Hard Drive & Hub (which is not enough space but the Hub???)
    ASAP feedbacks are truly appreciated.
    Thanks.
    Rashin Fahandej replied 18 years, 8 months ago 2 Members · 6 Replies
  • Rashin Fahandej
    December 29, 2007 at 2:33 pm
    By the way I am using Mac OS X 10.4.5.
    Is there any auto back up program for mac?
    Many Thanks
  • Bob Zelin
    December 29, 2007 at 3:16 pm
    never buy a Lacie drive.
    I see that by purchasing products like Lacie and Iomega, you probably go to the local office supply store to purchase these products. DO NOT DO THIS. Buy professional products from professional dealers. Even disount houses that are in OUR PROFESSIONAL BUSINESS.
    It is hard for me to recommend a drive, if you have not told us what computer you have. My first recommendation is to purchase an external SATA drive, but I don’t know your computer, so I can’t tell you what to purchase. Companies like Cal Digit and G-Tech are among many good companies to purchase single external SATA drives from.
    Bob Zelin
  • Rashin Fahandej
    December 29, 2007 at 4:30 pm
    Thanks Bob.
    I am using Mac OS X 10.4.5. (only have about 11Gb left on it)
    So I do need to keep my projects in the hard drive and work from there. I am having difficulty rendering or sometimes the play back. I thought it might be because of the USB connection.
    (This hard was a Lacie and I had to change the case beacuse the bridge failed in only 13month of work)
    Rashin
  • Rashin Fahandej
    December 29, 2007 at 4:42 pm
    Sorry I am new to this. Here is the full info:
    PowerBook G4 17″
    CPU Type: PowerPC G4 (1.2)
    CPU Speed: 1.67 GHz
    Bus Speed: 167 MHz
    thanks
  • Bob Zelin
    December 29, 2007 at 9:18 pm
    Hi Rashin,
    you are on the AJA Kona forum. What AJA product are you using ?
    Bob Zelin
  • Rashin Fahandej
    December 30, 2007 at 3:45 pm
    When I posted my message I received an email with the subject “Your post has been relocated”. So I assume they found a more fitted location???????
    Well, sorry to waist your time. Any suggestion for a proper place to get feedbacks?
