Activity › Forums › VEGAS Pro › external graphic card for Imac ? Is it possible in june 2013?
  • external graphic card for Imac ? Is it possible in june 2013?
    Posted by Marie-claude Sauvé on June 5, 2013 at 5:36 am
    Hello!
    I’ve made lots of search about ading an external graphic card to my I-mac i7 (with thunderbolt). I’s very hard to find out between all those differents advices.
    Is it now possible in june 2013?
    I use sony vegas in bootcamp and always have message of satured memory and I have to reboot often in order to make a render in HD.
    I have:
    3,4 GHz Intel Core i7
    16 Go 1333 MHz DDR3
    AMD Radeon HD 6970M 1024 MB
    Mac OS X Lion 10.7.5 (11G63)
    I use Vegas with Windows 7 64 bits
    And my bootcamp partition for windows is very large (80%)
    Any advices?
    Marie-Claude Sauvé
    http://www.deve.ca
    John Rofrano replied 13 years, 3 months ago 2 Members · 6 Replies
  • Marie-claude Sauvé
    June 5, 2013 at 5:38 am
    Ho yeah, forgot to say I use Sony Vegas 10
    Marie-Claude Sauvé
    http://www.deve.ca
  • John Rofrano
    June 6, 2013 at 11:32 pm
    Sony Vegas Pro 10.0 doesn’t make much use of a GPU (only for a few render formats) and you already have a AMD Radeon HD 6970M 1024 MB in your iMac. I’m not sure what you’re looking for but Vegas Pro 10.0 isn’t going to use it anyway.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
    June 7, 2013 at 12:00 am
    Ok, thanks for answering, at least this is clear!
    So I’ll have to find another solutions to my rendering problems.
    I often have messages that says virtual memory saturated even after a rebooting and with all programmes closed except Vegas.
    I have to make my big rendering (something like 10 minutes in full HD) in an another computer where I work.
    Is it normal with that kind of computer with this configuration?
    Thank you! That help a lot!
    Marie-Claude Sauvé
    http://www.deve.ca
  • John Rofrano
    June 7, 2013 at 10:36 am
    Running out of memory like that with 16GB of memory is not normal. Are you using the 32-bit or 64-bit version of Vegas Pro 10? You need to use the 64-bit version to take advantage of all of that memory. If you are using the 32-bit version you are only using 2GB which could be your problem.
    ~jr
    June 13, 2013 at 4:27 pm
    Hi John Rofrano!
    I want to thank you for your help! I now have Sony Vegas 64 bits and it work perfectly! A little detail that change everything!
    Have a wonderful day!
    Marie-Claude Sauvé
    http://www.deve.ca
  • John Rofrano
    June 14, 2013 at 12:07 pm
    You’re welcome. I’m glad that fix the problem for you.
    ~jr
