Activity › Forums › AJA Video Systems › External Frames in FCP greyed out
  • External Frames in FCP greyed out
    Posted by Crys on May 10, 2006 at 7:58 pm
    Hello…
    I am using AJA IO LA and when I start up Final Cut Pro, I get a message saying it is “Unable to locate the following external devices: ProIO – NTSC US – Component YPbPr SMPTE/N10 – 8-bit 422 (720 x…”
    I tell it to Check Again, but it won’t let me go on, so I choose to Continue.
    In the sequence, I cannot view anything on my monitor. I checked VIEW > EXTERNAL FRAMES, but the rest of the options are greyed out and I cannot choose to play ALL FRAMES.
    I have no idea why this happened all of a sudden. Was working fine before. I restarted the computer, but I still get the same result. What am I doing wrong?
    Any suggestions will be greatly appreciated!
    Thank you!!
    Jeremy Garchow replied 20 years, 4 months ago 2 Members · 5 Replies
  • Jeremy Garchow
    May 10, 2006 at 8:31 pm
    Check your firewire cable. Do you have any other firewire devices connected? If so, you need to separate the io from that firewire device with a PCI card or PCMCIA card.
    If the answer to above is no, then:
    Uninstall and reinstall the drivers. *warning* this will trash any easy setups you created as well as your FCP prefs.
  • Crys
    May 11, 2006 at 1:09 pm
    I’m sorry to sound stupid, but I’m pretty new to Macs…
    Could you tell me how to uninstall the AJA driver?
    I wanted to make sure before I messed up anything else.
    Thank you!
    P.S. No, I do not have any other firewire devices connected. So I will try to uninstall and reinstall.
  • Jeremy Garchow
    May 15, 2006 at 3:06 am
    Run the aja uninstaller:
    https://www.aja.com/ajashare/ProIO_Uninstaller.zip
    Jeremy
  • Crys
    May 16, 2006 at 4:35 pm
    Thank you! Uninstalling and reinstalling the driver solved the problem!!
  • Jeremy Garchow
    May 16, 2006 at 4:47 pm
    Sweetness. That usually scrambles the gremlins out of the system.
    Jeremy
