Activity Forums Apple Final Cut Pro Legacy External Firewire A/Bswitch causeing dropped frames?
  • Lee Berger
    October 31, 2006 at 8:46 pm
    I have this switch and it has been temperamental. If the cables are not seated just so you can have problems with the connection. Also I’m on my second unit from Sign Video. The first unit caused playback and capture problems. Sign Video willingly sent me a new box and it works fine as long as the cables are properly seated. Move the box too much and the connection can be lost. Also there is a limit to the length of the cables. I can’t remember what it is, but I have nothing longer than two meters on any port.
    That said I have been using the switch for almost two years with no other problems.
