Activity › Forums › Apple Final Cut Pro Legacy › External Drive Sratch Disk vs OS Drive Scratch Disk
  • External Drive Sratch Disk vs OS Drive Scratch Disk
    Posted by Christopher Targia on November 10, 2009 at 9:57 pm
    I have seen numerous times that it is beneficial to use an external drive as a scratch disk; I always just used the default setting as my scratch disk and it worked just fine for me. I decided when upgrading to FCS3 I would do things the right way as my projects are getting more complex… So I set up my external FW800 Drive to be the scratch disk, and even reassign my scratch disk folder for each project. This makes total sense for organization purposes; however, I am constantly getting dropped frames when things are not rendered. I know I can take unlimited RT off, but the sames un-rendered sequences that ran now drop frames and pause playback, this hampers my work-flow, is there a solution? It makes sense to me a 4 HD Raid 5 array would certainly be faster then a FW800 drive, should I just keep everything on my OS boot drive?
    Henry Bateman replied 16 years, 10 months ago 4 Members · 4 Replies
  • Aaron Neitz
    November 10, 2009 at 10:04 pm
    Never ever use your boot drive for media. It’s a bad habit to get into (like eating play dough). Not to say that in a pinch you can’t use it.
    Chances are that FW800 drive you have isn’t a particularly good one. Given that MacPro is using Sata drives internally, they can easily outrun the FW800 bus. What kind of codecs are you working in?
  • Christopher Targia
    November 11, 2009 at 2:11 pm
    DVCPro HD 720p
    its a WD MyBook 1TB, I am guessing I need to get a PCI-E card and get eSata support on my Mac Pro?
  • Walter Biscardi
    November 11, 2009 at 2:17 pm
    [Christopher Targia] “its a WD MyBook 1TB, I am guessing I need to get a PCI-E card and get eSata support on my Mac Pro?”
    Probably the worst external drive you could have chosen. Those are ok for backing up data but I would never recommend anyone edit off of one.
    Look at G-RAID units and offerings from Maxx Digital for proper external devices.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
  • Henry Bateman
    December 1, 2009 at 10:30 am
    I’m having the same problem with playback on an external monitor connected via dvi.
    All of my media is on a 2tb Gtech drive compressed using pro-res 422 (proxy) / 1920*1080/ 24fps and connected via fw800.
    I have a brand new macbook Pro so sadly it doesn’t have a pci port so although my ext drive is sata i can’t connect it faster then fw800.
    3.06GHz Intel core 2 duo / 8GB DDR3 ram
    I would have thought the macbook pro would have been fast enough to handle this setup. Do you think this is a hardware problem or setup?
    Many thanks
    Henry
