Activity › Forums › Adobe Premiere Pro › External drive options for editing 4k files in premiere on laptop?
  • External drive options for editing 4k files in premiere on laptop?
    Posted by Piotr Bryl on April 18, 2015 at 12:40 am
    I run a 17″ macbook pro 2.5ghz intel core i7 and currently using a G-RAID from about 5 years ago for video editing. It’s ok for my standard footage, but now with the GH4 4k files, premiere pro stalls whenever I try using the files. I do create proxies at this point, but I would rather just work with the 4K files directly. To do so, I’m assuming working off an external thunderbolt drive would do the trick, but I wanted to ask those who have had luck running 4k files on a laptop successfully. Anyone?
    If I must go with an external drive to run my 4k files, what do you recommend? I’m on a budget unfortunately.
    Would this suffice? https://store.apple.com/ca/product/HFY72ZM/A/lacie-3tb-d2-thunderbolt-2-usb-30-hard-drive?fnode=5f
    Kevin Rag replied 11 years, 5 months ago 3 Members · 2 Replies
  • Tero Ahlfors
    April 18, 2015 at 11:40 am
    You’d want a RAID like a Promise Pegasus thunderbolt one. One disk is pretty slow and it really doesn’t matter that much if it is on USB3 or thunderbolt.
  • Kevin Rag
    April 19, 2015 at 8:05 am
    +1 to what Tero says. You need a Thunderbolt RAID like the Promise Pegasus (RAID5) or if portability is more important the GRaid Thunderbolt (RAID 0) is good. I use them both and they serve me well. Caldigit and the other vendors here also offer Thunderbolt solutions.
    What NLE do you use? Editing 4K files natively also depends on the processor/playback engine used.
    Kannan Raghavan
    The Big Toad Films Pte. Ltd.
