Activity › Forums › Apple OS X › external drive is read only how do I make it writable
Posted by Michael Bigda on May 6, 2011 at 5:42 pmI have three external drives that I had on a PC and now I connected them to my MAC. They are read only. How can I write to them as well? Is the only way to reformat the drive?
Jl Serrapino replied 12 years, 11 months ago 8 Members · 11 Replies -
Alex Muir
May 6, 2011 at 5:49 pmIt could be how the drives were created, however to me, It sounds like a permissions problem.
If you select your drive and get info (cmd -I), at the bottom of the window you will see sharing and permissions (10.6.7) you may need to click the arrow to open the pane.
in that box you should see the users on the computer and their permissions. Read only, read and write.you can click next to the user name and change the permissions.
-Alex -
Michael Bigda
May 6, 2011 at 6:20 pmHey Alex,
When I open that up and go to the sharing and permissions area it only shows “You can only read” No options. All I did was connect my three drives to the Mac. Two were via ubs and the other was firewire. -
Alex Muir
May 6, 2011 at 6:43 pmMichael,
The method of connection should not matter.
Are you logged in with a user that has Admin privileges?Also in that sharing and permissions part of the get info window, there is pad lock, on the bottom left of the pane, that should be able to be unlocked so that you can make changes.
Also see if you can enable the tickbox that says “ignore ownership on this volume”
What is the format of your drive? it will tell you in the get info box.
-Alex
Michael Bigda
May 6, 2011 at 6:48 pmI am the admin user. And there is nothing you speak of. It is a NTFS and I guess that means I need to format it to FAT32 right?
Joel Hufford
May 7, 2011 at 10:38 pmHi Michael,
It sounds like your hard drive is formatted as an NTFS drive. Mac OSX cannot write to drives formatted as NTFS out of the box, so you’ll need to install some additional software in order to be able to read and write to the drive.
There are a couple of ways to go about this. Here is the the route I’ve gone on my Mac and it works fine, plus its free!
First, you’ll need to download and install MacFUSE
https://code.google.com/p/macfuse/then download and install NTFS-3G
https://www.apple.com/downloads/macosx/system_disk_utilities/ntfs3g.htmlThe NTFS-3G link above is for an older version of the software, however, it is the only version I have found that is free and it does everything I need it to do.
The only option you’ll be asked about is whether or not you’d like to enable caching on the drive. I always configure the software to enable the UBLIO caching as it speeds up the read/write process on the drive. However, if the drive is unmounted improperly, such as unplugging it or you experience a power outage, it is possible to lose information when the caching feature is enabled. The safer route would be to disable caching.
Hope that helps!
joel
Corporate and Special Event Staging Services
http://www.pacificstaging.com -
Jeff Greenberg
May 7, 2011 at 11:42 pmYou’ve already seen the right answer – that it’s likely an NTFS drive.
If you’re on Win7 and the Mac is 10.6.5 or later, you should reformat the drive as exFAT – it’ll let you read/write on both platforms AND have large file sizes.
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website -
Mitchell Pennell
July 14, 2012 at 8:09 pmWorked a treat
NTFS-3G Updated link for free version, which is not available on the app store
Jared Linzmeier
September 28, 2012 at 8:21 pmI attempted the steps listed and now I get this error when I connect the problematic external drives and I can neither READ NOR WRITE. Any tips?
NTFS-3G could not mount /dev/disk1s1
at /Volumes/FreeAgent Drive because the following problem occurred:dyld: Library not loaded: /usr/local/lib/libfuse.2.dylib
Referenced from: /usr/local/bin/ntfs-3g
Reason: image not found -
Sara Rebecca
October 10, 2012 at 3:02 amI have a mac, and recently found out my hard drive does work with it. But it is stuck in read only. can someone give me a step by step response on how to fix it??? like with numbers, letters or bullet points? i can only “view info” as far as i can find. PLEASE HELP ME!!! =(
