Activity Forums VEGAS Pro External Drive Dock for Media?
  • External Drive Dock for Media?
    Posted by Chas Smith on July 20, 2015 at 10:13 pm
    I’ve run into an issue and was wondering if any fellow Vegas users have some solution(s). Recently had Seagate Drive issues, long-story short: wound up having to reinstall Win7Pro (and everything else — UGH!). Replaced Boot drive with a SanDisk 240GB SSD…works fast! 🙂 Reloaded SVP10, 🙂
    But…. my EZ Dock eSata/USB setup is giving me fits. I’ve been retreiving archived raw-footage to rebuild the lost Vegas edits, etc. I copy from the EZ-Dock files onto another (New) Seagate HD on the PC for editing. Seems like during the process, the EZ-Dock HDs (I’ve tried different HDs mind you) seem to go along ok and then…HANG UP! 🙁 I’ve enabled all drives to cache. Keep things clean but dang if I know why this is happening. The eSata connection is good, all drives are connected good. Running 24GB Ram on ASUS X-58 Sabertooth Mobo, Intel 7 / 2.8ghz CPU… so no bottlenecks there.
    Got a tech-email out to Kingwin makers of the EZ-Dock. Searched forums …no real luck so far. Can’t imagine all these Seagate SATA3 HD’s are messing up all at once. Any ideas anyone?
    Chas
    John Rofrano replied 10 years, 9 months ago 2 Members · 1 Reply
  • John Rofrano
    July 20, 2015 at 11:18 pm
    It could be that the EZ-Dock itself is going bad. Try copying smaller batches of files. eSATA should be very reliable so maybe try a new cable or buy a new dock? I use a NewerTech Voyager and it works really well. I’ve used it in both eSATA and USB 3.0 mode and waven’t had any problems.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
