Activity Forums Adobe Premiere Pro External desktop monitor glitch: Premiere CC freezes everytime I rearrange panels & windows
  • External desktop monitor glitch: Premiere CC freezes everytime I rearrange panels & windows
    Posted by David l Rivera on June 13, 2016 at 8:53 pm
    I’ve started to encounter a glitch of some kind that happens every single time I execute a certain order of steps.
    I’ve got my comp connected to a 24″ external LG monitor via HDMI. After launching premiere, I undock some panels and move them over to the external monitor, no big deal. But the moment I select ‘color’ or ‘assembly’ or just start working in general, Premiere locks up. At this point, the glitch has 3 distinct properties aside from freezing.
    1) double clicking a clip in a bin for example does nothing. ‘Source’ window is completely grayed out.
    2) When I expand or contract the timeline vertically, the entire layout freezes into a “cascade of windows” effect. Kind of like a deck of cards splattered across a table.
    3) after force quitting premiere, I am unable to launch. I have to open a task manager to discover that it has dropped itself into ‘background processes’ for some reason.
    Despite the freeze, I can still move the playhead, and I can even hear the audio. I’ve repeated this process numerous times to confirm that it isn’t a random occurrence.
    Can anyone help shed some light on this please? Computer restart, no effect. I have re-installed, no effect. I have deleted media cache, no effect. Changed the name of both the adobe and premiere folders to “premiere.old” and “adobe.old”.
    I’ve also tested for the glitch using my work computer (a mid-level mac book pro running el capitan OS) which also has the latest version of CC, moving the interface around to other monitors, and it’s glitch free.
    I have near state-of-the-art computer specs as well, so that shouldn’t be an issue.
    MSI GT72 Dominator Pro gaming laptop
    64 bit, Windows 10
    6th gen, Intel skylake i7, 6820HK @3.1Ghz
    Nvidia GTX 980M with 8gigs ram
    32gigs RAM DDR4
    Any help is greatly appreciated!
    Blake Anderson replied 10 years ago 3 Members · 2 Replies
  • Duke Sweden
    June 14, 2016 at 2:34 pm
    I can’t help you, but I can contribute the fact that I also have a 2 monitor layout, one a 32″ HDTV (with HDMI connection) and a 22″ PC monitor (DVI). I have Premiere Pro laid out over the 2 monitors and have had no problems whatsoever so you should be able to as well. My “workstation” is just a regular consumer PC.
    The only difference between what I did and what you do is, I don’t arrange the windows every time I open Premiere Pro. I saved the layout. From what you’ve said I don’t think that’s gonna solve your problem, but if you do get things worked out, next time you lay out your windows save the configuration. For convenience sake if nothing else.
  • Blake Anderson
    September 13, 2016 at 4:56 am
    You described my current situation exactly. Have you been able to find a solution?
