Activity › Forums › Maxon Cinema 4D › external composition
  • external composition
    Posted by Gon Perdigao on May 2, 2009 at 6:07 pm
    I have a primitive that have a spline wrap animated, and i want to export the information to after effects, on a base of a null.
    I try to add the composition tag, to the object that have the spline wrap, to the spline wrap, and to the spline it self, and no luck.
    Can anyone help me? How can i manage to have the a null in after effects that made the same movement of the primitive that have the spline warp?
    Gon Perdigao replied 17 years, 4 months ago 2 Members · 4 Replies
  • Adam Trachtenberg
    May 2, 2009 at 10:59 pm
    I’m pretty sure I answered this same question a month or so when you asked it, and even provided a scene file.
  • Gon Perdigao
    May 3, 2009 at 11:38 am
    yes is true, sorry i didn’t saw that you have answer my post.
    I try your solution but, and i made all that you explain, but it’s not working.
    I’m having problems defining the point index, how can i do that?
    here is my project https://www.sendspace.com/file/km39o1
    Once more, sorry to not saw your previous answer, thanks a lot for your help
  • Gon Perdigao
    May 3, 2009 at 11:59 am
    i finaly figure it out!
    Thanks a lot for all!!!!!!!!
  • Gon Perdigao
    May 9, 2009 at 4:31 pm
    After rendering the scene, in after effects the nulls that i parent in cinema 4D aren’s in the place that i put them.
    In cinema 4D the nulls are right, is just in after effects that they are wrong.
    Do you know what might be?
    Can you help me?
    Thanks a lot!
