Activity Forums Adobe Encore DVD External burner but Encore writes to internal drive?
  • External burner but Encore writes to internal drive?
    Posted by Tim Taylor on March 16, 2008 at 8:36 pm
    I am trying to get Encore to write to my external DVD writer, but every time I export directly to disc from Premiere Pro CS3 (i.e. I don’t want to author menus) Encore insists on using my internal drive!
    I’ve read about changing the cable order of drives, but this is a laptop with an external drive so changing cable order is not possible.
    Can anyone offer suggestions what I might do next?
    Are Adobe aware of this bug, as it is a bug when you can’t select which drive you want to burn to!
    Or am I missing something in the set up?
    Tim Taylor replied 18 years, 6 months ago 3 Members · 2 Replies
  • Jeff Bellune
    March 16, 2008 at 9:39 pm
    Cancel the build once you are in Encore, then go to the Build tab and change which drive to burn to. Then build/burn again.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Tim Taylor
    March 28, 2008 at 7:11 pm
    Thanks….
    I’ve set the external drives drive letter to one that is alphabetically before the internal one, and now it is seen as default by Encore.
    A bad shortcoming by Adobe IMO
