Activity Forums Blackmagic Cameras External Battery Options
  • External Battery Options
    Posted by David C jones on May 13, 2013 at 1:36 pm
    Greetings,
    I was wondering what options or recommendations were out there for powering the BCC besides the internal batt. I’ve got a shoot coming up at the end of the month is which most of it will be exteriors.
    Best Always,
    Dave J
    Jeremy Wright replied 11 years ago 5 Members · 6 Replies
  • Deleted User
    May 13, 2013 at 5:02 pm
    [David C Jones] “I was wondering what options or recommendations were out there for powering the BCC besides the internal batt. …”
    External batteries & power cables appropriate for use with the BMCC are fairly easy to find these days.
    At the low-price end of the spectrum, Bescor sells a solution which reportedly works quite well with the BMCC:
    https://www.bhphotovideo.com/c/product/922934-REG/bescor_bcs_bmepic_bm_li_ion_battery_bm_cgr_auto.html
    There are also BMCC-specific external power solutions from IDX, Anton-Bauer, Hawk-Woods, IKAN, and many others. Some are of the V-lock variety, others use AB-type 3-stud mounts, others use Canon or Sony compact camcorder batteries, and others.
    Some batteries feature strong attachment systems with flexible designs to make it easy & quick to attach/detach the battery to your camera or rig. To a certain extent this comes down to personal preference — choose a battery system that works the way you like.
    In general, lithium-ion batteries weigh significantly less per watt-hour of capacity compared to nickel-metal hydride batteries. LI batts tend to be more expensive per watt-hour than Ni-MH, but both can be excellent values if made by reputable manufacturers.
    Don’t forget chargers: Some can be relatively expensive, and if so, be sure they have worthwhile features, such as fast charging times.
    Search your favorite video dealer’s website and the web. Lots of choices.
    I recommend against buying from a no-name supplier or least-cost eBay source. An incorrectly wired external power cable or battery system can damage your camera. Better to go with trusted brands and dealers.
    https://www.peterdv.com
    Blog: https://herefortheweather.wordpress.com
  • Matthew Sonnenfeld
    May 13, 2013 at 5:46 pm
    I use the Switronix BMC Jetpack. It’s expensive but it gives full power distribution to everything on your rig. It really is a life saver. It also has helped breath new life into my HPX170 which I now use on small shoots or sizzle reels with a hyperdeck shuttle. The Jetpack’s power cable for the camera powers the hyperdeck and Switronix makes a 7.2V LEMO to Panasonic CGR battery adapter. When both the BMCC or the Panasonic rigs are built up, it’s excellent.
    Of course, this makes sense if you have V-Mount or 3 stud batteries already or if you want to get into them. But you go all day on two bricks.
    Blackmagic Cinema Camera, RED Scarlet-X, Panasonic HPX170, Canon 7D
    2011 Macbook Pro 17″, 2.3 Ghz Quad Core, 16GB RAM
    AJA IoXT
    Adobe Production Premium CS6, Avid Symphony 6, Final Cut Pro Studio 3
    The College of William and Mary
  • Deleted User
    May 13, 2013 at 8:01 pm
    Hi Matthew: Thanks for mentioning Switronix, which I forgot. They make some great BMCC-specific products.
  • David C jones
    May 14, 2013 at 2:53 am
    Thanks guys for the recommendations!
    Dave J
  • Richard Campbell
    May 19, 2013 at 6:34 pm
    I second the Switronix Jet Pack. I have it for my BMCC (get the extension cable, as your particular configuration might require some extra length on the power cable). It powers multiple devices, including my wireless (2), Alphatron vf, and a Nanoflash.
    Richard Campbell
    Tvshooter Video Production
    Atlanta, GA
    http://www.Tvshooter.net
  • Jeremy Wright
    September 16, 2015 at 9:11 pm
    Hi, I know this is an old post. Just wanted to add this option, which I use: https://amzn.com/B013KWVXI2
    https://ecx.images-amazon.com/images/I/81xURP02fSL._SL1500_.jpg
    It’s a Juicebox battery specifically for the BMCC and was only $99. So far, it works great and I’ve already ordered a second for swapping purposes. Hope this helps anyone looking!
