Activity Forums Apple Final Cut Pro Legacy External A/V problem in FCP 5.1.4
  • External A/V problem in FCP 5.1.4
    Posted by Okeoma on June 29, 2007 at 3:15 am
    Please help,
    When I try to open FCP 5.1.4 installed in my MacPro system, I get this: “Unable to locate the following eternal devices – Apple FireWire NTSC (720×480). Then it tells me that my system configuration may have changed or my deck/camera may be disconnected or turned off.
    But that is not true. I connected my camera through firewire and made sure that it is turned. However, if I choose continue after repeated trial, then during log and cature, the camera can be controlled in FCP but no immage will come through, it will say “Preview Disabled”.
    I tried changing the external view option to all frames under view, but it repeatedly go back to off. I tried easy setup but no way
    PLEASE HELP
    Okeoma
    Okeoma replied 19 years, 2 months ago 3 Members · 4 Replies
  • Gordon Gurley
    June 29, 2007 at 5:02 am
    Are you trying to do HDV?
    Gordon Gurley
    Director of Operations
    Stanford Video
  • Okeoma
    June 29, 2007 at 5:21 am
    No I’m only trying to capture DV clips from my DV camera. I have done this before when this was installed newly without this problem.
  • Bill Bilowit
    June 29, 2007 at 6:08 am
    Try this if you didn’t after the install:
    https://docs.info.apple.com/article.html?artnum=301852
  • Okeoma
    June 29, 2007 at 6:37 am
    Tareco, Thnaks, thanks, thanks very much. it works very much. Now I can go to work. You guys made it possible.
