External audio slipping out of sync
I’ve looked through many posts on this but haven’t been able to find a solution, so wondering whether someone might be able and willing to assist me!
I’ve recorded a lecture with a Panasonic HDC-TM10, which uses AVCHD, and then (with the aid of these forums!) imported it into FCP7 with Log and Transfer using the Apple ProRes 422 (LT) – all well and good so far. Once I imported it, I’ve dragged it into a sequence and clicked yes for the sequence settings to match the clip.
I also used a line out of the sound system to record audio with Audacity, and exported that with the settings that the camera’s audio show in FCP – 48kz, 16 bit – then used PluralEyes to sync it up. Here is the issue.
It matches at the beginning perfectly, but as it continues the two audio feeds go drastically out of sync – more than 10 seconds by the end of the 75 minute lecture. I’ve seen that this is a common problem and have tried all the solutions I can find (or perhaps better put, understand), but at this stage nothing has worked. If anyone could shed any light on this then I would be eternally grateful…
Thanks in advance.
