Activity Forums Panasonic Cameras External audio recorders & Timecode
  • External audio recorders & Timecode
    Posted by David Raphael israel on September 21, 2007 at 4:25 am
    Hi —
    This question involves integration of camera with an external audio recorder.
    I’ve been shooting with an HVX-200 (PAL), focusing on music documentary work in India. I find a need to improve my audio gear, and am considering moving up to a high-resolution audio recorder. In reviewing current models and options, one issue I note is the possibility of synching up with a camera. For example, the Edirol Video R-4 Pro — see e.g. https://www.sweetwater.com/store/detail/R4Pro/ — boasts the ability so to synch, using SMPTE timecode received from a camera.
    Question is — does the HVX-200 have ability to send out such time-signal?
    I don’t have my camera with me (am in the US right now, camera is back in India), so can’t look at the thing and see if there’s any such “time-out” port. I don’t recall one . . . is it there somewhere?
    If not — I assume there’s no way of doing what I’m suggesting . . . in which case, I can safely ignore these more-costly machines that offer that option, and just hope for the best, synch-wise. Correct?
    Thanks for any input about this overall topic!
    cheers,
    d.i.
    david raphael israel
    bhopal, india
    Alfred Zigmund replied 14 years, 4 months ago 5 Members · 10 Replies
  • 10 Replies
  • Barry Green
    September 21, 2007 at 4:13 pm
    [david raphael israel] “Question is — does the HVX-200 have ability to send out such time-signal?”
    No… the HPX500 can do it, but not the HVX200.
  • David Raphael israel
    September 21, 2007 at 4:41 pm
    ah, thanks for the good clarification, Barry!
    Alas — more interesting & costly possibilities for future.
    cheers,
    d.i.
    bhopal, india
    September 22, 2007 at 9:34 am
    This new question somewhat jumps off from my earlier one.
    I’m planning to purchase a high-resolution audio recorder.
    Since it has been established that my camera (the HVX-200) does not generate a time-signal I can send to such a recorder, I will forget about getting those (high-cost) recorders that accept such timecode. Instead, my plan now is to bet the new, interesting audio recorder made by Korg — the MR-1000 (that can record in several formats including so-called “one-bit”).
    I figure that since I will also always simultaneously be recording an audio track with my camera, there really should not be a major synch problem in editing — since it’s just a question of lining up the 2 WAV files (in my editor of choice) . . . true, the synch may not be 100% equal in a deep micro level, but in practice, I imagine it will not be discernably off — or not enough to to really matter.
    Is this speculation reasonable?
    thanks!
    d.i.
    bhopal, india
  • Barry Green
    September 22, 2007 at 1:03 pm
    Totally reasonable. But instead of just trying to line up waveforms, I strongly suggest you get a clapper slate. It’s sooooo much easier to line up by the “clack” than to try to overlap waveforms. 🙂
    September 22, 2007 at 1:27 pm
    Ah excellent idea, Barry, thanks.
    I’ve now put a nice (el cheapo) $10 clapper slate (with old-style chalkboard)
    https://www.bhphotovideo.com/c/product/66812-REG/Delta_22910_Chalkboard_Production_Slate.html
    into my B&H basket … along with a copy of your HVX Book, btw.
    cheers,
    d.i.
    bhopal, india
  • Jim Blokland
    September 22, 2007 at 2:17 pm
    Hello:
    A slightly more costly solution, which we’re using on an HVX feature right now — a Smart Slate that has visual timecode readout from the 4-track hard drive recorder. This allows us to have a visual reference when synching the BWAV files from the recorder, so even though it’s a manual synch job, it’s a bit faster than searching the audio file for the clap mark.
    We did a synch test for a ten-minute run, and it was rock solid between the camera and recorder.
    Hope this helps.
    Best, JIM.
    OSX.4.10
    Dual 2.7 G5
    3.5 GB RAM
    Radeon X800 XT
    Kona 2 / K-Box
    Seritek 1.5 TB RAID
    AVID XPRESS PRO/MOJO
    September 22, 2007 at 3:50 pm
    Interesting, Jim. Probably not necessary for the sorts of things I anticipate doing in near-term — but a novel (to me) idea to be aware of.
    At this point, since my camera (HVX200) can’t be electronically synched with an outside audio recorder, ergo I’m not aiming to buy a recorder that does time-synching. Far as I’ve seen, those are more costly — like I saw specs on a nice Editrol Pro model that can both send and receive timecode; but it costs about $2K.
    The $1200 I’ll likely spend on the Korg MR-1000 is about as high as I want to go . . . I’m in “low budget” territory (relatively speaking).
    If there are other solid-state recorders closer to the $1K mark, I’d be interested to know about them. (I like the Korg partly because it has a 40-gig HD — good for field recording situations — plus the intrigue of “1-bit” format, etc.)
    I guess this is veering into audio gear territory now.
    At any rate, thanks for the good info.
    cheers,
    d.i.
    bhopal, india
  • Aksel Fauzi
    November 10, 2010 at 7:54 pm
    Hi Barry
    I have R4 & HPX171 & HXV202
    but I am not able to output the audio from my R4 to my camera
    can i do it with just an XLR cable or i need a AESEBU ? or there is another solution
    thank you
  • Aksel Fauzi
    November 14, 2010 at 8:45 pm
    Hi Barry
    I have an Edirol R-4Pro & HPX171 & HXV202
    thank you
  • Alfred Zigmund
    May 6, 2012 at 6:50 am
    can u explain please how can i sync Edirol R4 Pro with Hpx 500 ? i have both the voice recorder and camera but can’t use em without clap i’m looking for something like this: when i will sync the voice recorder with the camera and when i press Rec on cam the voice recorder must record voice automatic if its possible, please explain in detail which cable i need etc etc and where i need to connect the camera, i know only 1 way in camera the BNC cable must be in TC out and in Edirol R4 pro in TC in, im wrong i guess cause it was not worked :(( sorry for bad english
