Activity › Forums › Apple Final Cut Pro Legacy › external audio monitoring
  • external audio monitoring
    Posted by Kim Rowley on December 29, 2005 at 9:32 am
    I posted over on the AJA forum but I thought to do so here too as there’s a bit more traffic. Just want to pick the brains of the pro’s regarding how you’ve set up your external audio monitoring gear. I have the AJA I/O and lay back to tape using the SDI embedded audio signal. My question relates instead to audio monitoring during the editing process. I am a recent convert to FCP over from M100 so am relatively new to the AJA/FCP setup. I am currently using the output of the G5 and realize that’s a big no-no. I know there’s a whole gamma of products available. I was just curious as to what works for you all in terms of mixers and speakers – also which self powered ones are good.
    Thanks for anybody’s time.
    Dual 2.7 GHz G5, 4GB RAM, ATI Radeon 9650, Xserve RAID, AJA IO, 2 20″ Cinema Display, FCP 5.03, OS X10.4.3
    Kim Rowley replied 20 years, 9 months ago 3 Members · 6 Replies
  • Gunleik Groven
    December 29, 2005 at 10:49 am
    You cannot go wrong with Genelec audio monitors. They’re very good and reliable and used all over broadcast here in Norway at least.
    I am quite confused of how to accesss the SDI audio signal and use e.g. an AJA og BM device for audio mix and mastering with or without an external AD/DA.
    The audio is embedded in the video signal on the SDI connection, right?
    Then what?
    Gunleik
  • Kim Rowley
    December 29, 2005 at 11:07 am
    Thanks for your reply. I’ll look into that brand. As for the embedded audio, yes the video and audio all travel down the same cable. I capture through the AJA I/O using the SDI input and can select any of the up to 4 channels of audio recorded on the tape. Same is true for output to tape. I go straight from the AJA I/O into the SDI in of the Digital Betacam deck. I have output up to 4 channels simultaneously from FCP to Digibeta (sometimes we do several language editions of the same show).
    Hope this helps.
    PS Rome may be similar to Norway at the moment. It’s snowing heavily. Quite a sight!
  • Paul Ingvarsson
    December 29, 2005 at 11:09 am
    Hi Kim,
    As I understand it (not owning an AJA I/O) you have analogue audio outputs as well as SDI embedded in the Video signal. I would connect these to a PPM meter that as outputs that can drive the imputs to speakers – Genelecs are good albeit expensive if it’s your own money. If you can get a PPM meter that has a volume control switch as well. Just make sure yourself or an engineer calibrates the PPM’s to match your SDI output with a reference tone. Most PPM units have red LED’s to warn of high levels as well – although they do vary depending on the ballistics of the units themselves (ie how quickly they react to short sharp sounds in your mix)
    With all this digital audio routing I personally stay away from ‘audio’ mixing desks and would opt for a control surface mixing desk instead. The advantage of this is that your entire audio ‘mix’ would be contained in the FCP project and not rely on you having your desk set up exactly the same way each time you return to the project. The Mackie MCU receives quite a lot of praise and is a control surface mixer.
    Paul
  • Kim Rowley
    December 29, 2005 at 11:21 am
    Points well taken. The AJA has both analogue and digital outputs, though currently I’m only using the SDI In and Out. I just saw the Mackie unit you mention this morning on the web. I have to look into further as I think besides the control surface unit I’d still need an amplifier if I don’t have the self powered speaker, right? It’s kinda pricey ($1000 on the B&H website), but may be worth it….
    At the risk of sounding publicly really stupid… what exactly is a PPM unit?
    Thanks Paul.
    kim
  • Paul Ingvarsson
    December 29, 2005 at 12:02 pm
    Kim,
    All about PPM’s – we use them a lot in broadcast in the UK
    https://www.murraypro.com/PPM.htm
    A real audio mixer won’t provide you with a built in amp. Most Nearfields like the Genelecs are self powered – ie have amps inside them – they also have volume knobs on them if you don’t mind using them – otherwise som ething like this would do:
    https://www.colemanaudio.com/swtchr.htm
    Check the PS1A
    Paul
  • Kim Rowley
    December 29, 2005 at 2:24 pm
    Great food for thought, Paul.
    Thanks a million.
    Kim
