Activity Forums Adobe Premiere Pro External Audio linked markers
  • External Audio linked markers
    Posted by Dave Baum on March 22, 2021 at 10:17 am
    Hi all, looking for some help please, I’m working with interviews with sound recorded separately on a lavalier / sound recorder. I’ve unlinked the guide camera audio, deleted that track and then synced the lavalier audio and linked the two tracks.
    When I select the linked tracks and add a marker, the markers added to video and audio are not alined, despite the audio and video being in sync. And original files are very close in terms of timecode and start / end / duration. Seems very haphazard – at times no marker added to audio, other instances on timeline the markers are absolutely miles apart.
    Is this a bug? Or user error? Is there a way around this?
    Thanks in advance
    Dave Baum replied 5 years, 6 months ago 2 Members · 2 Replies
  • Bret Hampton
    March 22, 2021 at 3:50 pm
    Dave
    If you put the clips and audio in the timeline and link them when you click on the clip to add a marker it should add to both.
    It concerns me you unlinked camera audio. Now you have no absolute sync for reference. If it were me, I would use Multicam to synch audio, using the external recorder as your main track. The camera audio will still be connected in case you need it.
  • Dave Baum
    March 22, 2021 at 5:57 pm
    Thanks for the reply Bret. I can add the original back as a reference. I’m just finding that the timings are out on the audio markers for some reason. Eg I add a marker 47f, marker appears at f47 on video but f27 on the audio. And the markers are not always added to the audio, even when I apply them to linked video and audio. So it’s a bit inconsistent. I’ll double check it’s not a track selection thing, but any other suggestion would be most welcome! Thanks
