Activity Forums Maxon Cinema 4D exterior light
  • exterior light
    Posted by Tatra Tero on December 17, 2009 at 2:19 pm
    hello,
    what is the best render setup for architectural still image render,that give realism to the scene.
    i use 1-sky object (objects-sky-create sky)
    2-GI
    only
    its very good setup,but i feel thats maybe it need more to give it realism,any Suggestion . with thanks
    Adam Trachtenberg replied 16 years, 9 months ago 3 Members · 4 Replies
  • Randy Johnson
    December 17, 2009 at 3:31 pm
    I like a well selected HDR on a sky object to add extra highlights and reflections.
    /Randy
  • Tatra Tero
    December 17, 2009 at 7:16 pm
    with gi ,or without??
    second there is two type of sky 1- object-scene-sky
    2- object-sky-create sky
    wich one of theme
  • Randy Johnson
    December 18, 2009 at 7:09 am
    Yes GI.
    Yes AO as well.
    One sky at a time but do two multi-pass renders and Mix them to your liking in Photoshop.
    /Randy
  • Adam Trachtenberg
    December 18, 2009 at 4:10 pm
    There is no “best” solution — just different tools to achieve different looks. One way to go about it is with pure lighting (no GI). In that respect you can use an infinite light to represent the sun and any number of fill lights to represent ambient illumination. You can also supplement that with the environment object’s ambient setting (but a little goes a long way).
    Or you can use the above in combination with GI or GI/HDRI.
    Or you can use GI/HDRI alone….
    Or in combination with ambient occlusion….
    Personally I prefer not to use the built-in sky system as I find it takes away too much control.
    If you use lights, it’s generally a good idea to use a warm color for the sun light and bluish colors for fill lights. Not a bad idea to add a subtle bluish tint to shadows, too.
