Activity Forums Adobe After Effects Expressions ExtendsScript – dynamic variable names function loop – Help
  • ExtendsScript – dynamic variable names function loop – Help
    Posted by Ronan De lacy on January 25, 2021 at 9:37 am
    Hello,
    Hoping someone can point me in the right direction. I have a script that creates a shape layer with a series of horizontal lines on a single shape layer. These lines will represent a grid.
    I have everything working, by manually creating each group and name but trying to shorten my code to create the same result using a loop.
    Here’s what I have that works;
    var addLayer = app.project.item(5).layers;
    //Add Headline Grid
    var addGrid = addLayer.addShape();
    addGrid.label = (13);
    addGrid.name = ("headline-text-grid"
    var group1 = addGrid.content.addProperty("ADBE Vector Group");
    group1.name = "P1";
    var myShapeGroup = group1.content.addProperty("ADBE Vector Shape - Group");
    var myShape = new Shape();
    myShape.vertices = [
    [-compWidth / 2, -compHeight / 2],
    [compWidth / 2, -compHeight / 2]
    myShape.closed = false;
    // set the value of th path too the shape object
    myShapeGroup.property("ADBE Vector Shape").setValue(myShape);
    var stroke = group1.content.addProperty("ADBE Vector Graphic - Stroke"); // add a stroke
    var p1 = group1.property("ADBE Vector Transform Group").property("ADBE Vector Position");
    p1.expression = "[0, effect('Pos-1')('Slider')];"
    var group2 = addGrid.content.addProperty("ADBE Vector Group");
    group2.name = "P2";
    var myShapeGroup2 = group2.content.addProperty("ADBE Vector Shape - Group");
    var myShape2 = new Shape();
    myShape2.vertices = [
    myShape2.closed = false;
    myShapeGroup2.property("ADBE Vector Shape").setValue(myShape2);
    var stroke2 = group2.content.addProperty("ADBE Vector Graphic - Stroke"); // add a stroke
    var p2 = group2.property("ADBE Vector Transform Group").property("ADBE Vector Position");
    p2.expression = "[0, effect('Pos-2')('Slider')];"
    var group3 = addGrid.content.addProperty("ADBE Vector Group");
    group3.name = "P3";
    var myShapeGroup3 = group3.content.addProperty("ADBE Vector Shape - Group");
    var myShape3 = new Shape();
    myShape3.vertices = [
    myShape3.closed = false;
    myShapeGroup3.property("ADBE Vector Shape").setValue(myShape3);
    var stroke3 = group3.content.addProperty("ADBE Vector Graphic - Stroke"); // add a stroke
    var p3 = group3.property("ADBE Vector Transform Group").property("ADBE Vector Position");
    p3.expression = "[0, effect('Pos-3')('Slider')];"
    And here’s my attempt of shortening the above using a loop. The intention is for the loop to repeat 7 times. Can anyone tell me where I’m going wrong?
    Many thanks,
    Ronan
    //Add Headline Grid
    addGrid.name = ("headline-text-grid");
    function createGrid(){
    var group = [];
    var myShapeGroup = [];
    var myShape = [];
    var stroke = [];
    var p = [];
    for (i = 1; i <=7; i++){
    group[i] = addGrid.content.addProperty("ADBE Vector Group");
    group[i].name = "P"+[i];
    myShapeGroup[i] = group[i].content.addProperty("ADBE Vector Shape - Group");
    myShape[i] = new Shape();
    myShape[i].vertices = [
    myShape[i].closed = false;
    myShapeGroup[i].property("ADBE Vector Shape").setValue(myShape[i]);
    stroke[i] = group[i].content.addProperty("ADBE Vector Graphic - Stroke"); // add a stroke
    p[i] = group[i].property("ADBE Vector Transform Group").property("ADBE Vector Position");
    p[i].expression = "[0, effect('Pos-"[i]"')('Slider')];"
    Ronan De lacy replied 5 years, 8 months ago 2 Members · 3 Replies
  • Filip Vandueren
    January 25, 2021 at 10:02 am
    You defined the function createGrid(), but you didn’t execute it.
    Just add:
    createGrid();
    and it will run.
    I haven’t checked the rest of the code to see if it would indeed run correctly.
  • Filip Vandueren
    January 25, 2021 at 10:11 am
    As for the rest of the script, you used [i] in two places where it won’t work:
    should be
    group[i].name = "P"+i;
    and
    I’m guessing it should be (depending on what you named your Sliders):
    p[i].expression = "[0, effect('Pos-"+i+"')('Slider')];"
    Finally, compWidth and compHeight aren’t defined, but they might be global variables in some part of your code that you didn’t post.
  • Ronan De lacy
    January 25, 2021 at 10:22 am
    Hi Filip,
    Thank you so much – all if your suggestions worked.
    And yes, compWidth and compHeight are globals within the larger script.
    Cheers,
    Ronan
