Activity › Forums › Adobe After Effects Expressions › ExtendScript selected layer index
Posted by James Ronan on April 15, 2016 at 4:09 pmHi all, Sorry I know this isn’t expressions but couldn’t see an ExtendScript forum.
For my first ExtendScript project I’ve created a panel with a button! When I click my button (myButtonCtrl) I want to retrieve the index number of the layer currently selected, and show it in an alert. So far I have this, however it doesn’t appear to be working.
myButtonCtrl.onClick = function () {var layerIndex = app.project.activeItem.selectedLayers.index;
alert (layerIndex);}
Any ideas?
James
James Ronan replied 10 years, 5 months ago 2 Members · 7 Replies -
Dan Ebberts
April 15, 2016 at 7:42 pmWhat you get with selectedLayers is an array. So something like this would give you the index of the first selected layer:
var myLayers = app.project.activeItem.selectedLayers;
if (myLayers.length > 0){
alert (myLayers[0].index);
}else{
alert ("No layers selected.");
Dan
James Ronan
April 16, 2016 at 10:39 amThanks a lot Dan! That works perfectly! One more Question…
when the button clicks I also have a variable that creates a new solid:
var newSolid = app.project.activeItem.layers.addSolid([0,1,0], "My First Solid", 1920, 1080, 1.0, 10);It automatically puts the solid at the top (Index 1) What I’d like it to do is add it one above the selected layer…
So far I’ve tried a few combinations but nothing is working.
Any suggestions?
Thank you again!!
James
James Ronan
April 16, 2016 at 11:00 amAlso, when I said ‘one above’ I was thinking of the timeline and actually meant an index of -1
I’ve been trying to figure it out and I think that because once you add a new solid, the selected layer index is going to change +1
so far this what i’ve wrote but it isn’t working.
newSolid.index = (layerIndex[0].index - 1); -
Dan Ebberts
April 16, 2016 at 4:08 pmTry it this way:
newSolid.moveBefore(myLayers[0]);
Dan
James Ronan
April 16, 2016 at 10:05 pmHey thanks so much that works! What is the reason for the [0] after myLayers?
Really appreciate the help… but I have one more question (last I promise). After the solid has been moved to correct index, I wanted to change the myLayers (The layer originally selected) Track Matte to Alpha.
I’ve added:
myLayers.trackMatteType = TrackMatteType.ALPHA;However it doesn’t seem to work. I’ve tried a few different lines of code and I think the issue is coming from the .selectedLayers.
This works if I specify the layer:
app.project.activeItem.layer(7).trackMatteType = TrackMatteType.ALPHA;The complete code is now:
var newSolid = app.project.activeItem.layers.addSolid([0,1,0], "My First Solid", 1920, 1080, 1.0, 10);if (myLayers.length > 0){
}Thanks once again.
James
Dan Ebberts
April 16, 2016 at 10:22 pmYou almost have it. Try it this way:
myLayers[0].trackMatteType = TrackMatteType.ALPHA;
myLayers is an array of the layers selected at the time you run the script. myLayers[0] is the layer that was selected first. The 0 is the index into the array, which gives you the first array element, or in this case, the first selected layer.
Dan
James Ronan
April 16, 2016 at 10:34 pmAh Yes! that makes sense. Wow thank you so much!
Really helped, thanks a lot Dan
James
