Activity Forums Adobe After Effects Expressions Extendscript naming Dropdown Menu effect
  • Extendscript naming Dropdown Menu effect
    Posted by Willem De rue on February 25, 2020 at 10:10 am
    Hello,
    I’m writing a simple script where I add a dropdown menu effect to a layer, but I can’t seem to rename the Dropdown Menu effect like with for instance a slider effect.
    var dropdownItems = [
    "Left",
    "Center",
    "Right"
    boxLayerDropdown = boxLayer.Effects.addProperty("ADBE Dropdown Control");
    boxLayerDropdown.property(1).setPropertyParameters(dropdownItems);
    boxLayerDropdown.name = "Align";
    What am I doing wrong here?
    Regards,
    Wim
    this throws “Object is invalid, while this is fine:
    boxLayerslider= boxLayer.Effects.addProperty("ADBE Slider Control");
    boxLayerslider.name = "Rounded corners";
    Brie Clayton replied 1 year, 9 months ago 5 Members · 7 Replies
  • 7 Replies
  • Alex Munteanu
    February 25, 2020 at 8:04 pm
    I haven’t tested ‘Dropdown’ controls much.
    When I try to get their matchName they also showup as a Pseudo-effect, which is a bit weird.
    Anyways… what you could do instead is to rename the last added effect.
    boxLayer.Effects.property(boxLayer.Effects.numProperties).name = "Align";
  • Dan Ebberts
    February 25, 2020 at 8:13 pm
    The dropdown control is an unusual implementation. You could try this:
    "Left",
    "Center",
    "Right"
    var boxLayerDropdown = boxLayer.Effects.addProperty("ADBE Dropdown Control");
    var temp = boxLayerDropdown.property(1).setPropertyParameters(dropdownItems);
    temp.propertyGroup(1).name = "Align";
    Dan
  • Willem De rue
    February 27, 2020 at 8:43 am
    Thanks Dan, that did the trick (of course)!
  • Fede Parodi
    December 23, 2024 at 1:36 pm
    Hi, I have a similar situation. In my case, I would like to be able to change the active item in the dropdown menu.
    I guess it would be something like this:
    “Left”,
    “Center”,
    “Right”
    var boxLayerDropdown = boxLayer.Effects.addProperty(“ADBE Dropdown Control”);
    temp.propertyGroup(1).name = “Align”;
    temp.propertyGroup(1).setValue(1); // Here I want to set a default value at “Center” but it’s not working.
    Do you know how can I change the values of a dropdown menu?
  • Dan Ebberts
    December 23, 2024 at 2:56 pm
    I’m not sure this is what you’re asking, but it appears that setting the parameter list invalidates your object reference, so to change the selection afterwards, you need to re-establish the reference with a full property spec path, like this:
    boxLayer.property("Effects").property("Dropdown Menu Control").property(1).setValue(2);
  • Fede Parodi
    December 23, 2024 at 10:01 pm
    Thanks a lot Dan! That solved it
  • Brie Clayton
    December 24, 2024 at 3:59 pm
    Thank you for solving this, Dan!
