ExtendScript for After Effects
So I’m trying to learn and teach myself ExtendScript for After Effects, and I learned how to kinda reverse engineer a layer and dial down its properties to get the property name and its Adobe Match Name. I was able to create a for loop to do this, but it only does the first “column” of properties.
What I want: I want to be able to create a script that will display the entire hierarchy of the selected layer showing the property and its sub-properties (see image).
Below is the code I have that just gives me the first level of property names:
var project = app.project; var comp = project.activeItem; var lName = "test" ; var theLayer = comp.layer(lName) /*--I set a ridiculous number in the for loop so I can figure out how many properties there are. Unfortunately ExtendScript (to my knowledge) won't count the length of the property group. The TRY CATCH method will stop the loop.--*/ for (var i=1; i<1000; i++){ try{ var theLayer2 = theLayer.property(i).name; $.writeln(i+" Name: "+theLayer.property(i).name+'\<wbr>n'+ i+" MatchName: "+theLayer.matchName+'\n \n'); } catch (e){ break; } }This is the output I get for the selected shape layer using the above script.
1 Name: Marker 1 MatchName: ADBE Vector Layer 2 Name: Contents 2 MatchName: ADBE Vector Layer 3 Name: Masks 3 MatchName: ADBE Vector Layer 4 Name: Effects 4 MatchName: ADBE Vector Layer 5 Name: Transform 5 MatchName: ADBE Vector Layer 6 Name: Layer Styles 6 MatchName: ADBE Vector Layer 7 Name: Geometry Options 7 MatchName: ADBE Vector Layer 8 Name: Material Options 8 MatchName: ADBE Vector Layer 9 Name: Audio 9 MatchName: ADBE Vector Layer 10 Name: Sets 10 MatchName: ADBE Vector Layer
