Activity Forums Adobe After Effects Expressions Extendscript AE Object Library
  • Extendscript AE Object Library
    Posted by Paul Benson on December 3, 2009 at 3:27 pm
    Found threads on the Cow and at Adobe with no response, so trying again. Hoping this is a real easy check for someone so that I can know whether or not it is a common problem or something I need to fix with my system (WinXP).
    When I open Extendscript and click on the flyout in the editing window or go to Help->Object Model Viewer, it shows only ‘Adobe Bridge CS4 Object Model’, ‘Adobe Device Central CS4 Object Model’, ‘Adobe Illustrator CS4 Object Library’, and ‘Adobe Photoshop CS4 Object Library.’
    No object model or library for AE (or Premiere, or Soundbooth, or…).
    Thank you,
    Pauley
    Paul Benson replied 16 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 3, 2009 at 3:54 pm
    That’s the same thing I see when I open it.
    Dan
  • Paul Benson
    December 3, 2009 at 4:11 pm
    Thanks Dan. I’ll stop worrying about it, then.
    Pauley
