Activity Forums Adobe After Effects Expressions Extendscript – Adding a vector shape to a group.
  • Extendscript – Adding a vector shape to a group.
    Posted by Billy Sides on December 20, 2017 at 5:02 pm
    I need help figuring out how to add the shape to a group. I need access to the group transforms so I can position each of the paths I am creating.
    Here is an image of what I would like to achieve.
    https://drive.google.com/file/d/1OEzRtp1ILlZR7L5T_7BPfk-JlYiaQRPg/view?usp=sharing
    var sVerts= [[-4.66796875,-4.614013671875],[-4.66796875,-1.584716796875],[4.701171875,-1.584716796875],[8.44921875,1.823486328125],[8.44921875,3.798095703125],[4.701171875,7.206298828125],[-4.66796875,7.206298828125],[-8.44921875,3.798095703125],[-8.44921875,3.387939453125],[-5.3125,2.809814453125],[-5.3125,4.512939453125],[5.283203125,4.512939453125],[5.283203125,1.208251953125],[-4.048828125,1.208251953125],[-7.833984375,-2.199462890625],[-7.833984375,-3.797607421875],[-4.048828125,-7.206298828125],[4.498046875,-7.206298828125],[8.283203125,-4.072998046875],[8.283203125,-3.729248046875],[5.248046875,-3.082275390625],[5.248046875,-4.614013671875]];
    var sITans= [[0,0],[0,0],[0,0],[0,-2.7265625],[0,0],[2.86328125,0],[0,0],[0,2.693359375],[0,0],[0,0],[0,0],[0,0],[0,0],[0,0],[0,2.728515625],[0,0],[-2.83203125,0],[0,0],[0,-2.51806640625],[0,0],[0,0],[0,0]];
    var sOTans = [[0,0],[0,0],[0,0],[0,-2.7265625],[0,0],[2.86328125,0],[0,0],[0,2.693359375],[0,0],[0,0],[0,0],[0,0],[0,0],[0,0],[0,2.728515625],[0,0],[-2.83203125,0],[0,0],[0,-2.51806640625],[0,0],[0,0],[0,0]];
    logoShapeLayer = activeItem.layers.addShape();
    logoShapeLayer.name="S Path";
    sShapeGroup = logoShapeLayer.property("ADBE Root Vectors Group");
    sShapeGroup.addProperty("ADBE Vector Shape - Group");
    logoShapeGroup.addProperty("ADBE Vector Graphic - Fill");
    var sShape = new Shape();
    sShape.vertices = sVerts;
    sShape.inTangents = sITans;
    sShape.outTangents = sOTans;
    sShape.closed = true;
    sShapeGroup.property(1).property("ADBE Vector Shape").setValue(sShape);
    -bsides
    Billy Sides replied 8 years, 7 months ago 1 Member · 1 Reply
  • Billy Sides
    January 3, 2018 at 6:15 pm
    I figured out how to add the paths to the groups, but now I’m stuck on how to access the correct group.
    I can’t figure out where to put the name or index of the group I’m trying to access. The way the code is now the first group is the one being modified. Any help or direction would greatly be appreciated.
    var sOTans = [[0,0],[0,0],[2.86328125,0],[0,0],[0,2.693359375],[0,0],[-2.859375,0],[0,0],[0,0],[0,0],[0,0],[0,0],[0,0],[-2.83203125,0],[0,0],[0,-2.73095703125],[0,0],[2.658203125,0],[0,0],[0,0],[0,0],[0,0]];
    logoShapeLayer.name="Logo";
    var sShapeGroup = logoShapeLayer.property("Contents").addProperty("ADBE Vector Group").property("Contents").addProperty("ADBE Vector Shape - Group");
    //var sSapeGroupIndex = sShapeGroup.propertyIndex;
    sShapeGroup.name="S";
    sShapeGroup.property("ADBE Vector Shape").setValue(sShape);
    sShapeGroup = logoShapeLayer.property("Contents").property("ADBE Vector Group");
    sShapeGroup.property("ADBE Vector Transform Group").property("ADBE Vector Position").expression = "[178.6709,7.2063]";
    var cVerts= [[-4.7529296875,-4.545166015625],[-4.7529296875,4.444580078125],[4.7158203125,4.444580078125],[4.7158203125,1.382080078125],[8.2646484375,2.094970703125],[8.2646484375,3.798095703125],[4.4755859375,7.206298828125],[-4.5146484375,7.206298828125],[-8.2646484375,3.798095703125],[-8.2646484375,-3.797607421875],[-4.5146484375,-7.206298828125],[4.4755859375,-7.206298828125],[8.2646484375,-3.797607421875],[8.2646484375,-2.401611328125],[4.7158203125,-1.893798828125],[4.7158203125,-4.545166015625]];
    var cITans= [[0,0],[0,0],[0,0],[0,0],[0,0],[0,0],[2.8671875,0],[0,0],[0,2.66015625],[0,0],[-2.86328125,0],[0,0],[0,-2.73095703125],[0,0],[0,0],[0,0]];
    var cOTans = [[0,0],[0,0],[0,0],[0,0],[0,0],[0,2.693359375],[0,0],[-2.896484375,0],[0,0],[0,-2.693359375],[0,0],[2.8671875,0],[0,0],[0,0],[0,0],[0,0]];
    var cShape = new Shape();
    cShape.vertices = cVerts;
    cShape.inTangents = cITans;
    cShape.outTangents = cOTans;
    cShape.closed = true;
    var cShapeGroup = logoShapeLayer.property("Contents").addProperty("ADBE Vector Group").property("Contents").addProperty("ADBE Vector Shape - Group");
    //var cSapeGroupIndex = cShapeGroup.propertyIndex;
    cShapeGroup.name="C";
    cShapeGroup.property("ADBE Vector Shape").setValue(cShape);
    cShapeGroup = logoShapeLayer.property("Contents").property("ADBE Vector Group");
    cShapeGroup.property("ADBE Vector Transform Group").property("ADBE Vector Position").expression = "[158.6709,7.2063]";
    -bsides
