Activity Forums Adobe After Effects Expressions Extendscript: Add Pseudo Effect
  • Extendscript: Add Pseudo Effect
    Posted by Simon Heimbuchner on October 18, 2018 at 7:39 am
    Hey there,
    A script I’m working on adds a few control effects to a layer.
    For aesthetics, I’d like them to be added as a Pseudo Effect. Is there a reliable way to do this in Extendscript that doesn’t require the user of the script to fiddle around in some deep down XML files?
    I know there’s extendscript syntax supporting XML (new XML()), but afaik it’s mostly focussing on creating/reading/writing XML files as a way of exchanging data.
    Help is much appreciated.
    Thanks alot in advance,
    Simon
    Lenny Mason replied 6 years, 9 months ago 6 Members · 10 Replies
  • 10 Replies
  • Alex Printz
    October 18, 2018 at 5:32 pm
    I’ve used the pseudo effect maker plugin before with great success.
    https://aescripts.com/pseudo-effect-maker/
    Alex Printz
    Mograph Designer
  • Simon Heimbuchner
    October 18, 2018 at 5:57 pm
    Hey Alex, thanks for your response!
    I’ve actually used that plugin before – either I’m missing something or I didn’t phrase my request correctly, sorry.
    Is there a way to create a Pseudo Effect from within a script, like you would add an effect? like: mySolid.property("Effects").addProperty("ADBE Slider Control")
  • Dan Ebberts
    October 19, 2018 at 12:51 am
    For a script to be able to add a pseudo effect with addProperty(), the effect needs to be defined in the PresetEffects.xml file. Your script could check that file to see if it’s in there, add the XML code if it isn’t, save the file, restart AE, then add the effect (of course you’d probably have to save a temporary copy of the current project so you could restore the context after restarting AE). Quite a pain actually.
    I generally do all that by hand on my system, add the effect to a layer, and save the effect as a preset. Then my script can just add the preset to a layer without the pseudo effect having to exist in the local PresetEffects.xml file. Much easier.
    Dan
  • Simon Heimbuchner
    October 23, 2018 at 7:35 am
    Hey Dan,
    Thanks a lot for your clear and detailed response.
    That actually is quite a lot of pain, wow. Sounds like a few frustrating hours of work.
    I guess I’ll just have to work without fancy Pseudo Effects then.
    Simon
  • Santi Agustí
    October 23, 2018 at 10:52 pm
    I think you will love this splendid piece of code by Tomas Sinkunas.
    You need to save your pseudo as .ffx , then convert it to binary and follow this approach:
    https://bitbucket.org/snippets/rendertom/qj5M4/apply-pseudo-effect-as-animation-preset
  • Simon Heimbuchner
    October 24, 2018 at 7:59 pm
    Wow, this is amazing! What a cool piece of code. Thanks a lot for bringing this up, works great for me.
  • Simon Heimbuchner
    October 30, 2018 at 9:43 pm
    Hey, me again – I’ve been out of town and only got around to test the code snippet as provided.
    Now, trying to include my own ffx, I failed with converting ffx to binary.
    Any help with that? Extendscript’s Convert to Binary doesn’t seem to help, and the only alternative I’ve stumbled upon is this script (https://aescripts.com/file-to-binary-converter/) for sale at aescripts. Seems a bit of stretch for a seemingly simple problem.
    Thanks again for your help.
  • Simon Heimbuchner
    December 16, 2018 at 9:08 pm
    Just for anyone reading this post – I did end up buying the script.
    Motion Designer
    Website: https://simonheimbuchner.de/
  • Tomas Sinkunas
    April 21, 2019 at 11:37 am
    Hey Simon. Sorry for a late reply, but I also have a snippet to convert files to binary strings as well. Check it out:
    Convert to Binary
  • Lenny Mason
    December 12, 2019 at 12:11 am
    Hi, I’ve used your script to convert my pseudo to binary and I’ve used Santi Agustí’s link to apply it to that code, but when I try to run it, I get an error saying: ‘null is not an object’. Not sure what I’m doing wrong, I’ve only changed the presetBinary…
