Activity Forums Adobe After Effects Extendscript: Add keyframes to hidden property
  • Extendscript: Add keyframes to hidden property
    Posted by Simon Heimbuchner on January 1, 2019 at 4:19 pm
    Hey guys,
    as the title says, I’m trying to add keyframes to hidden properties.
    Pretty straight forward, this is my code:
    var Comp = app.project.activeItem;
    var currentLayer = Comp.selectedLayers[i];
    currentLayer.effect("Test")(5).setValueAtTime(Comp.time,myValue = 5);
    The effect that’s being called is just a hidden Slider Control I made with Pseudo Effect Maker.
    The error message I get is this:
    Unable to execute script at line 3. After Effects error: Can not "set value at time" with this property, because the property or a parent property is hidden.
    I have a strong feeling there’s just no way to achieve this. However, I’d be really happy if anyone knows a workaround for this problem.
    Thanks in advance,
    Simon
    Motion Designer
    Website: https://simonheimbuchner.de/
    Simon Heimbuchner replied 7 years, 8 months ago 1 Member · 1 Reply
  • Simon Heimbuchner
    January 1, 2019 at 4:26 pm
    Whoops. I just figured it out myself. Seems like i set it up wrong.
    Basically, I had a few hidden Slider Controls inside a hidden group. The double-hidden setup seemed to be the problem. Once I removed the “invisible” property from the actual Slider Controls, it all worked fine.
    EDIT: Whoops again. The Slider Controls are hidden in the effects panel, but visible in the timeline, once you do the “u u” shortcut.
    Anyone still up for this?
    Motion Designer
