Activity Forums Adobe After Effects Expressions ExtendScript – add expression to opacity property
  • ExtendScript – add expression to opacity property
    Posted by Paul Connors on November 1, 2016 at 3:49 pm
    Hello,
    I’m currently writing a script and am stuck on trying to automatically add an expression to a specific composition. Currently my script creates a new comp named: “Precomp1”. It also creates another composition within “Precomp1” named: “Item 1”. I’m trying to then automatically add an expression to the opacity property for “Item 1.” Here is my current code:
    var MasterComp = app.project.activeItem;
    var Precomp1 = app.project.items.addComp("Precomp1", 1920, 1080, 1, 60, 29.97);
    MasterComp.layers.add(Precomp1);
    var Item001Comp = app.project.items.addComp("Item 1", 1920, 1080, 1, 60, 29.97);
    Precomp1.layers.add(Item001Comp);
    Any ideas?
    Thank you!
    Paul Connors replied 9 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 1, 2016 at 4:45 pm
    Like this, I think:
    var Precomp1 = app.project.items.addComp(“Precomp1”, 1920, 1080, 1, 60, 29.97);
    var Item001Comp = app.project.items.addComp(“Item 1”, 1920, 1080, 1, 60, 29.97);
    var myLayer = Precomp1.layers.add(Item001Comp);
    myLayer.property(“Opacity”).expression = “75”;
    Dan
  • Paul Connors
    November 1, 2016 at 6:17 pm
    Hi Dan. That’s fantastic! Thank you very much. I’m able to get it to work with a simple expression like “75” or even “wiggle(2,50)” but I’m struggling to add a more complex expression to that opacity property. I have an expression from another project I’m trying to incorporate here. That working expression looks like this:
    C = comp("Master");
    ctrl = C.layer("Controls").effect("Slider Control")("Slider");
    L = C.layer(thisComp.name);
    val = Math.round(ctrl.valueAtTime(time+L.startTime));
    if (val == index) 100 else 0
    Do you know how would go about incorporating that to opacity expression help you offered above?
