Activity Forums Adobe After Effects Extending length of video frame in project without slowing video speed
  • Extending length of video frame in project without slowing video speed
    Posted by Nick Yule on September 2, 2015 at 6:49 am
    I am working with a range of AE Templates for intros and promo.
    In alot of these templates, there will be a slide show style, and they are usually on screen for a period of around 5 seconds (probably because alot of people just use photos).
    If I stretch the time length for that part of the composition, the section extends longer which is great, I can fit good 10-20 second chunks of video in, but it it into slow motion. I don’t want this.
    Is there any way I can extend a section of a template without compromising the speed of the video I put into it?
    TIA.
    Walter Soyka replied 11 years ago 2 Members · 3 Replies
  • Walter Soyka
    September 2, 2015 at 9:41 am
    If the video is contained within a precomp, you’ll have to open up that precomp and extend its duration, then adjust the timing of layer in/out points and keyframes in the main comp.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Nick Yule
    September 3, 2015 at 6:55 am
    Yes… my video length already exceeds the duration of the precomp…
    how do I go about adjusting the timing of layer in/out points and keyframes in the main comp.
    ty
  • Walter Soyka
    September 3, 2015 at 9:04 am
    You can click and drag. You can lasso-select keyframes the same way you’d lasso-select icons on your desktop, then drag them left or right. You can drag layers in the timelime left and right. You can drag the end of a layer to extend it.
    Since you’re new to After Effects, I’d recommend the following link, in which Adobe’s Todd Kopriva pulls together some important introductory materials:
    https://blogs.adobe.com/toddkopriva/2010/01/getting-started-with-after-eff.html
    Walter Soyka
