Activity Forums Adobe After Effects Extending Footage Question
  • Alon_a
    May 10, 2006 at 4:38 am
    Apply time remapping (Ctrl+Alt+T) to the footage layer first. You can then extend it as much as you want.
    AA
  • Aharon Rabinowitz
    May 10, 2006 at 10:55 pm
    Miguel – you can’t extend the layer until AFTER you time remap. Once remapping is applied, then you can extend it, but only to the duration of the comp. So if your comp is 10 seconds, you won’t be able to make you’re clip any longer than 10 seconds.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
