Activity Forums Adobe After Effects Extended Comp Doesnt render beyond original length
  • Extended Comp Doesnt render beyond original length
    Posted by Joseph M. morgan on September 1, 2009 at 11:24 pm
    I created a new project (CS4) and started working, then changed my mind and extended the comp length from 30 to 45 seconds. The comp doesn’t work beyond 30 seconds.
    Any ideas at all??
    Joseph M. morgan replied 17 years ago 30,051 Members · 1 Reply
  • Joseph M. morgan
    September 2, 2009 at 12:04 am
    I solved it. I may have had something to do with the paint effect I had on the comp. Not sure why that particular effect, as other comps I had created later and subsequently extended didn’t have the same issue.
    I simply deleted and recreated the paint effect, and it took on the new length.
