Activity Forums Adobe Premiere Pro Extend to CTI
  • Extend to CTI
    Posted by David Erwin on November 9, 2008 at 4:44 pm
    I’m looking for (or least be able to define) a shortcut that extends the outpoint and/or in point to the current time line indicator.
    I don’t know if I have just missed in the shortcut documentation or if it does not exist?
    Jiri Fiala replied 17 years, 10 months ago 3 Members · 3 Replies
  • Jiri Fiala
    November 13, 2008 at 3:57 pm
    I don’t think you can do this, you can only trim (not extend) in/out points to CTI, and you’ve got to map these functions yourself via Keyboard customization.
  • Jon Barrie
    November 13, 2008 at 8:35 pm
    This workflow is not a shortcut based system. You can use the CTI as a snapping point and Ripple out the clip to the CTI and when it snaps let go of the mouse.
    While using the Select/Move Tool (V) hold down the Ctrl (PC) or Apple (mac) button and the tool becomes the Ripple Tool – once you let go of the keyboard button you have the Select/Move Tool again.
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Jiri Fiala
    November 13, 2008 at 9:16 pm
    Yes, I consider CTRL rippling one of the greatest Premiere workflow features.
