Activity Forums Adobe Premiere Pro Extend edit
  • Extend edit
    Posted by Richard Taylor on April 15, 2013 at 9:18 pm
    Can Premiere Pro perform an extend edit past another edit point?
    If not, if I place the target playhead at an edit point and perform an extend edit, will the edit go all the way to the playhead?
    RT
    Kevin Monahan replied 13 years, 5 months ago 4 Members · 7 Replies
  • 7 Replies
  • Aindreas Gallagher
    April 15, 2013 at 10:05 pm
    wait for 7 – four weeks out – i think this might be what you’re on about?
    https://vimeo.com/62439842
    https://vimeo.com/user1590967/videos http://www.ogallchoir.net promo producer/editor.grading/motion graphics
  • Richard Taylor
    April 15, 2013 at 10:52 pm
    Thanks, Aindreas.
    That is exactly what I’m on about.
    Richard
    Richard
  • Alex Hawkins
    April 16, 2013 at 12:16 am
    Hi Richard,
    If I understand you correctly CS6 has the functionality at the moment to do what you are asking. You might just have to map a couple of keyboard shortcuts. Just open up the keyboard shortcuts box and search ‘extend’.
    You’ll figure it out from there.
    Hope that helps.
    Alex Hawkins
    Canberra, Australia
    April 16, 2013 at 12:25 am
    to be fair I’m still basically bluffing with 6 – but there is an edit extend issue depending on the scenario. it kind of depends whether you are pushing a roll decision edit through the next clip point? That said, I could just boot up PPr6.
    Still a tinkerer before PPro 7 ET mothership lands. Which does fix that scenario.
  • Alex Hawkins
    April 16, 2013 at 1:18 am
    Yes Aindreas I see what you mean. A roll edit won’t go past the next edit but a ripple will.
    Again, if I understand you correctly?
    Alex Hawkins
    Canberra, Australia
  • Richard Taylor
    April 16, 2013 at 8:29 am
    So the real issue I was asking about is clearly explained in the video that Aindreas linked to above.
    Premiere Pro (and some other NLEs) previously could not trim a clip to a zero duration. That always left a minimum of a single frame when extend editing or ripple or roll trimming to the end of a clip or to an edit point.
    FCP7 can actually trim right past an edit point and into the next clip.
    Richard
  • Kevin Monahan
    April 16, 2013 at 7:34 pm
    [Richard Taylor] “Can Premiere Pro perform an extend edit past another edit point?”
    No, you can only extend to the next edit point. You can extend again if you want to extend past two edit points. Make al feature request if you want it to pass through multiple edits: https://www.adobe.com/go/wish
    [Richard Taylor] “If not, if I place the target playhead at an edit point and perform an extend edit, will the edit go all the way to the playhead?”
    Yes. We can now trim to zero duration.
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
