Activity › Forums › Adobe After Effects Expressions › extend background indefinitely
  • extend background indefinitely
    Posted by Michael Nikitin on June 18, 2009 at 9:13 pm
    Hi guys,
    I have a background movie that I’d like to use (looping it indefinitely), which is several times shorter than the comp I’m working with.
    Short of duplicating the movie 99 times and lining up the duplicates back to back, using that as the background — is there an expression that would do the job, instead?
    Michael
    Michael Nikitin replied 17 years, 3 months ago 2 Members · 4 Replies
  • Dan Ebberts
    June 18, 2009 at 9:33 pm
    There is, but why not just use File > Interpret Footage > Main and set however many loops you need?
    Dan
  • Michael Nikitin
    June 18, 2009 at 10:00 pm
    Why not? Because I was completely oblivious of that option. 🙂 That certainly solves the prbolem.
    Thanks, Dan!
    Out of curiosity — what would the expression be, and which parameter would it be affecting?
  • Dan Ebberts
    June 18, 2009 at 10:15 pm
    You would enable time remapping and add a simple time remapping expression:
    loopOut()
    You also need to extend the layer’s outpoint, and add another keyframe if you want the loop to be exact.
    Dan
  • Michael Nikitin
    June 18, 2009 at 10:26 pm
    Got it. Thanks again!
