Activity Forums DaVinci Resolve EXR Workflow Questions…
  • EXR Workflow Questions…
    Posted by Alexander Higgins on March 19, 2012 at 8:45 pm
    Hello Everyone, I am just wondering how people are doing workflows with EXRs.
    In our shop all EXRs are rendered in LINEAR, but it seems that DaVinci is sRGB. So when I bring in Linear EXRs they are of course dark and when I write my own LUT from NUKE using the color matrix I can get them really really close, but not exact, the blacks are still a hair off.
    Can anyone let me know how people are using EXR’s in DaVinci and if they are using LINEAR EXR’s, HOW?
    Are you guys using a LINEAR to sRGB LUT?
    If so and its better than MINE, can I have it?
    Thanks.
    Andreas Bravin karlsson replied 13 years, 4 months ago 9 Members · 15 Replies
  • 15 Replies
  • Martin Wehding
    March 19, 2012 at 11:46 pm
    we are using exr’s in a r3d workflow for vfx shots. Try and set the colorspace in the write node in nuke to rec709 instead of linear.
  • Teo Rižnar
    March 20, 2012 at 7:26 am
    Rec709 in EXR out in Nuke will clip info and would not be the same like linear render and than lin-rec709 LUT. I will be doing similar thing soon. Will post my progress if I get somewhere 😉
    Color grade reel: https://vimeo.com/15480583
    Cofounder of https://nuframe.si postproduction
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Jimmy Christensen
    March 20, 2012 at 2:08 pm
    Since when did Nuke clip info in Rec709?
  • Timor Kardum
    March 23, 2012 at 4:19 pm
    Try to set the R3D in Davinci to “RedLogFilm” and then export to EXR.
    To be hosest: i am not 100% sure this is correct, we are still checking it, but where quite successful with it so far.
    We will now test ACES and open-colorIO, lets see where this leads us…
    Timor
    http://www.omstudios.de
  • Frank Maier
    March 25, 2012 at 1:56 am
    Had a similar issue with After Effects. In my case AE used a different Iso settings on the R3d files then Davinci. After dialing in the same value for the iso it was pixel-perfect…
  • Jimmy Christensen
    March 28, 2012 at 12:27 pm
    Funny you should mention OpenColorIO. The new OCIO nodes in Nuke 6.3v7 actually clips (at 1.25) when going to rec709.
    The normal colorspace converter in Nuke doesn’t clip anything when going to rec709.
  • Adrian Brindle
    May 7, 2012 at 1:52 pm
    Hi Alexander,
    Did you ever get a final answer to this?
    I have exactly the same problem and we’re fairly sure we need a linear to SRGB Lut.
    Or we need to get Resolve to read the file as linear.
    Adrian
  • Jonathan Berube
    June 8, 2012 at 9:42 am
    Hello,
    It seems I’m facing the same challenge. I’m trying to grade full CG frames rendered 16bit Half Float Open EXRs in Linear Color Space.
    DaVinci Resolve will let me import and grade away but I’m unable to find the proper sRGB Display LUT for my viewer config.
    Nuke’s viewer will do the proper Lin to sRGB display LUT conversion and so as RV but no sRGB LUT in DaVinci.
    I guess most Colorists are outputting to Film or HDTV (Rec709) but my final out put is web.
    Any hints on how to solve this?
    -J
  • Adrian Brindle
    June 8, 2012 at 10:31 am
    I didn’t get any real resolution to my last post, no one offered a lut. (Still welcome if you have it)
    What I did was import a scene into after effects which correctly scaled the shot.
    I then exported this as a jpeg and imported it into resolve as a still.
    I then used this still to build a grade on a node to correctly scale the shot in resolve.
    I didn’t make this as a lut but I could of I suppose.
    This approximation was my starting point and I applied this to all on a node. I then graded on separate nodes after this.
    The results were fine and I seem to have access to plenty of latitude.
    Bon Change
  • Andreas Bravin karlsson
    June 25, 2012 at 5:12 pm
    I’m a Nuke compositor and do not know Resolve, but I find it really strange that a professional grading application does not have something as basic as a Lin to sRGB LUT. I’ve exported a LUT out of Nuke that I hope will do the trick for you:
    lintosrgb.cube.zip
    Let me know if you prefer a different format.
    Andreas Bravin Karlsson
    VFX Supervisor
