Activity › Forums › Adobe After Effects › EXR gives black frames in after effects
  • EXR gives black frames in after effects
    Posted by Gon Perdigao on May 5, 2010 at 9:24 am
    I’m building an exr project, and when i import a sequence some frames are black, but if i import that frames to the timeline they are ok.
    I’m working with a quadcore with 4gb of memory, after effects cs4 updated, the exr files are at 32 bits floating.
    What can i do to fix the problem?
    Thanks a lot
    Gon Perdigao replied 16 years, 4 months ago 33,596 Members · 1 Reply
  • Gon Perdigao
    May 6, 2010 at 9:25 am
    well thanks a lot, but the info that was there i already knew, and there’s no solution to my problem.
    Did this happen to anyone of you?
