Activity Forums Maxon Cinema 4D Expresso Math Node
  • Expresso Math Node
    Posted by David Biederbeck on December 29, 2011 at 6:38 pm
    Simply trying to rotate wheels with the time. Using a math node to speed it up a bit. I thought I could just multiply by two to make the rotation go double the amount of time.
    But it appears to be going both positive and negative, can anyone tell me if my expresso looks flawed?
    David Biederbeck replied 14 years, 8 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    December 29, 2011 at 7:17 pm
    Looks like it should work. Are you using keyframes AND Xpresso?
  • Brian Jones
    December 29, 2011 at 7:24 pm
    if your wheels are rotated 180 to put them on the other side of the vehicle you would have to rotate those wheels the other direction but other than that like Adam said it looks like it should work
  • David Biederbeck
    December 29, 2011 at 7:39 pm
    Rockstar. Thanks.
